Off-site hosted 3CX
Discussion in 'Windows' started by Jetcityjules, Aug 5, 2009.
  1. Jetcityjules
    Feb 17, 2009
    6
    We have been having some real Internet issues in our small, rural valley. Consequently, our phone system goes down. We are investigating our options, and one we were hoping was out there was another company that hosts 3CX for us. Anyone know anything about that?
    Thanks,
    Julie
  2. Yakko
    Jun 24, 2009
    5
    You surely can find a server farm for hosting your server but if you have internet issue you will be unable to connect to the server in the server farm....
  3. gicl
    Mar 17, 2009
    5
    I'm using 3CX hosted in a VM in an external datacenter.
    Charles
  4. Discovery Technology
    Apr 19, 2008
    278
    What country are you in?
  5. tpinnovations
    tpinnovations Member
    Jul 30, 2009
    296
    http://3cxhost.com
  6. DeWild1
    Oct 31, 2008
    86
    I use 2 adsl lines.
    It is best to get 2 different internet connections that are different like one Cable one ADSL.
    It is best to get a server that is local.
  7. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Don't use VoIP as your primary circuit. I will never recommend that as a configuration.
  8. tpinnovations
    Jul 30, 2009
    296
    I have to agree with Kerry on this.
    You are going to want your server on site and to use a local PSTN or PRI. If you were in the city my suggestion would be totally different.
    Hosting is somewhat out because that requires a stable internet connection. So if your connection goes down all your calls will be answered, but will never reach the phones.
