Office 365 Address Book Integration
Discussion in 'CRM / Helpdesk / App Integration' started by Nate, Apr 4, 2017.
  1. Nate
    Apr 4, 2017
    I have a Standard license that I am working on setting up. On the edition comparison page, under application integration, it states that Office 365 is supported within the Standard edition for address book only. However I cannot find any documentation on how to set this up. All I can find is with the complete Office 365 integration which doesn't seem to work on my instance.
    Thanks for you help.
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,673
    131
    Hi @Nate,
    The integration with Office 365 is only available in PRO/ENT license keys.
    What you have in the STD edition is the synchronization of contacts with Office 365. Here you have the docs:
    https://www.3cx.com/user-manual/phonebook/
    From that page what you need is this:
    From the 3CX Client for Windows you may also “Sync” your online accounts to import contacts. You have the ability to sync “Office 365” and “Google.” Go to “Settings”, “Import Contacts” and fill in the appropriate details.
    Kind regards.
  3. Nate
    Apr 4, 2017
    That's exactly what i needed, thanks.
