Solved Office 365 Public Folder Contacts not syncing
Discussion in '3CX Phone System - General' started by ITSteve, Nov 15, 2017.
  1. ITSteve
    Sep 13, 2017
    22
  2. ITSteve
    Sep 13, 2017
    22
    Can someone at least direct me to how to check the logs, so I can investigate on my one? I have exported the Support/Generate Support Info and looked at that, but can't find anything about this connection attempt.
    Thanks.
    #2 ITSteve, Nov 16, 2017
  3. ITSteve
    Sep 13, 2017
    22
    It is working now. For the future, the syntax is:
    Address Book/Consultants
    Address Book
    I was incorrectly prepending Public Folder, like Public Folder/Address Book
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,400
    535
    Glad to hear the issue is now resolved and thank you for sharing your solution
