Office Hours and DST + server in UTC
Discussion in '3CX Phone System - General' started by Vic D'Elfant, Aug 22, 2011.
  1. Vic D'Elfant
    Oct 11, 2009
    24
    Hi all,
    The cause of the issue is that have our server running in UTC, but to start off: that's something that can't/won't be changed.
    3CX is installed on this server, and it obviously uses the system clock for its own time calculations. However, since we live in GMT + 1 (with DST), the office hours are off twice a year. This is nothing but a minor inconvenience, but is there any chance we could set a different timezone from within 3CX? This should only be possible if the server runs in UTC, of course.
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    No 3CX runs depandant of the system clock, this canot be changed. My suggestion is to run it in a VMWAre machine with a diffrent system time.
