Office Hours per Group
Discussion in 'Ideas' started by Eric Miller, Mar 22, 2016.
  1. Eric Miller
    Nov 18, 2015
    I would like the ability to set different Office Hours per Extension group.
    I know that each extension can have unique office hours, but it would be nice to be able to set them at the group level.
    Possibly change the option at the extension level to be with the group OR custom and then be able the set the whole Group to be either Global or Custom as well.
