Office Hours
Discussion in '3CX Phone System - General' started by frenchy, Jun 25, 2010.
  1. frenchy
    Aug 27, 2007
    23
    Hi !
    Is it possible with v9 to configure different Offices Hours by VOIP Providers ?
    For example : Office Hour A for VOIP Provider A and Office Hour B for VOIP Provider B and C.
    regards,
    François
  2. bangsjaman
    Jun 1, 2009
    37
    I guess you want this for outbound rules? Then I dont think it is possible, but maybe it could be a nice feature to suggest..
    But in v9 you can set different office hours for each inbound rule.
  3. shedster99
    Aug 3, 2009
    29
    This is exactly what I set out to look for tonight.
    It's perfect if you use multiple trunks with better rates at different times, let the rules determine which trunk the calls go outbound according to cost :)
