Office hours
Discussion in '3CX Phone System - General' started by Tomas Raska, Sep 19, 2017.
  1. Tomas Raska
    Aug 18, 2017
    59
    6
    Hello I do not understand how Office Hours work.
    Can you explain it me?
    When I set Office hours for first Number in DID, same settings I see in Trunk/Gateway settings.
    When I set diferent Office hours for second Number, in Trunk/Gateway settings is still setings from first Number.
    When I delete Office hours from Gateway settings, then same settings from DID, from first Number disappear.
    I think is it not too much clear for me
  2. IoannisM_3CX
    IoannisM_3CX Support Team
    Aug 10, 2017
    229
    18
    Hello @Tomas Raska
    Is you first DID's number the same with the Trunk's number?
