Officially supported USB headsets for 3CXphone for Windows
Discussion in 'Windows' started by 3CXusername, May 2, 2016.
  1. 3CXusername
    3CXusername New Member
    Jul 31, 2014
    183
    16
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,379
    84
    I would recommend going on the sites of the Headset manufacturers directly and look at their compatibility list. As you mentioned Jabra and Plantronics, they also have on their website compatibility lists for the which of their products work with 3CX, generally though if you have the Jabra Direct software or the Plantronics Spokes (not Hub), then it should work, but double-check to be sure.
    Also one more common issue I have heard about in regards to the headset controls, if the headset is a wireless one, I believe you need the companies own bluetooth/Wifi dongle which is sometimes seperate, otherwise the controls will not work.
  3. 3CXusername
    Jul 31, 2014
    183
    16
    thanks for the reply. But http://www.3cx.com/support/plantronics-configuration/ says download Hub (no mention of Spokes).
    Could you clarify?
    Anyone have a recommendation on a good inexpensive "entry level" USB headset?
    thanks.
  4. NickD_3CX
    Jun 2, 2014
    1,379
    84
    My bad, I just got word that now the Hub Plantronics software should work now.
  5. 3CXusername
    Jul 31, 2014
    183
    16
    We ended up getting Plantronics C320. While not "inexpensive" I am very happy with their performance.
