Old version of softphone
Discussion in 'Windows' started by Gregpearce, Jun 27, 2016.
  1. Gregpearce
    Sep 21, 2015
    6
    Hi guys,
    Does anyone know where i can find old versions of 3CX phone for Windows?
    All of the download links i can find are for V14 SP3, but we are running V14 with no service pack.
    The new softphone is not compatible with the pre SP1 versions of 3CX and we cannot upgrade to SP3 due to our antivirus.
    Thanks in advance,
    Greg
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    814
    49
  3. Gregpearce
    Sep 21, 2015
    6
    Thanks for the reply Frank,
    The link you sent doesn't appear to be active, i keep getting page time out.
    Do you know if it is hosted elsewhere?
    Regards,
    Greg
  4. complex1
    Jan 25, 2010
    814
    49
    I've just checked the link, a download window appears and I can download the file.
    I'm using FF as browser and it works.
    Try https:// in front of the link.
