Omg-how to access external line?
Discussion in '3CX Phone System - General' started by pacificbih, Jan 15, 2009.
  1. pacificbih
    Jan 15, 2009
    Hello
    Ok Iv setup extension its ok - green (on c450ip siemens phone)
    Iv setup VoIP provider - ok, its green
    How to hell to make a external call, on any PSTN central is 9 conventional exit, but here?
    For example how to call germany (+49 xx xxx xxx)?
    Thanx for answer
  2. mbaltus
    Dec 12, 2008
    66
    Outbound rule!
    You need to create one so that 3CX knows that all calls starting with a 9 (or 0 or whatever) are intended to go to the VOIP provider.
    In the outbound rule you need to strip the first digit (which is default), since the 9 shouldn't be provided to the voip provider.
  3. alexmallia
    alexmallia New Member
    3CX Support
    Aug 4, 2008
    130
    You may find more information on the outbound rules on the following link:
    http://www.3cx.com/manual/3CXPhoneSystemManual7/phone-system41.html
    regards
  4. voipbaennjer
    Jul 10, 2009
    44
    Had success, does it work????
