on connect I here disturbing Audio sounds
Discussion in '3CX Phone System - General' started by prakashvr, Nov 15, 2010.
  1. prakashvr
    Nov 15, 2010
    When I call an extention - on connect I here disturbing Audio, like a voice prompt but can not make out the words
    What could be the problem?
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    You probably have a haunted PBX :p, naah if you can upload a wireshark capture of the call being made I might be able to point you in the right direction.
