On Demand Recording
Discussion in '3CX Phone System - General' started by Galileoden, Aug 11, 2013.
  1. Galileoden
    Aug 11, 2013
    Does 3CX provide the ability to record a conversation on demand via an IP Phone (yealink)? The client would like to be able to press a key combination to start a recording on demand.
    If not, is there any way to instruct 3CX to delete recordings when you set it to 'always record'?
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    65
    While I have not tried it, the yealink's do have a record option that you can set for the DSS keys. You will need to access the phone's settings via its web interface and make the changes and then try. As indicated, I have not tried it and therefore do not know if it will actually work.
    3CX allows for full recording control using the MyPhone application. You can manage the recordings as far as deleting them as well as there is no auto-delete functionality.
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
    The record button does seem to work with v11 and shows up in the MyPhone app. Ensure you have the correct functionality turned on under the extension in the console.
    I have not tested in v12 yet.
    I prefer using the phone to record as MyPhone does not tell you what it is actively recording - does it?
