On Hold music doesn't work
Discussion in '3CX Phone System - General' started by Daikoku, Sep 29, 2007.
  1. Daikoku
    Sep 22, 2007
    28
    I'm having troubles getting on hold music to work. Here's an excerpt from the log:
    05:23:08.798 MediaServerReporting::RTPReceiver [MS005001] Call(21) Ext.100: Wrong data length 0 for payload 0
    05:22:58.830 MediaServerReporting::RTPSender [MS004000] Call(21) Ext.100: (ACTIVE): Can't send RTP stream to 0.0.0.0:16482 destination unreachable
    Any idea why this might happen?
  2. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Tell us a bit more so we can help.
    The call is from where? to where?
    Cheers
  3. Daikoku
    Sep 22, 2007
    28
    It's an external call coming in via Sipgate to extension 100.
  4. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Odd, looks to me for what is shown on the log that 3CX or in this case Sipgate isnt sending the Ip address so that 3CX knows where to send the rtp :|
    Cant help you there im afraid
    :cry:
  5. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Are the calls working? Audio in and out? Did you check the firewall?
    Can you post a log of the entire call from start, hold, pickup etc. ?
  6. Daikoku
    Sep 22, 2007
    28
    yep calls work fine without problems. Here's the full log:
    11:53:31.310 StratLink::eek:nHangUp [CM104001] Call(36): Ext.100 hung up call; cause: BYE; from IP:84.153.105.xxx
    11:53:27.967 MediaServerReporting::RTPSender [MS104000] Call(36) Ext.100: (ACTIVE) RTP stream to 84.153.105.xxx:16474 restored.
    11:53:21.076 MediaServerReporting::RTPSender [MS004000] Call(36) Ext.100: (ACTIVE): Can't send RTP stream to 0.0.0.0:16474 destination unreachable
    11:53:17.763 CallLegImpl::eek:nConnected [CM103001] Call(36): Created audio channel for Ln:10000@Sipgate (217.10.68.xxx:35664) with Media Server (206.71.149.xxx:9058)
    11:53:17.763 StratInOut::eek:nConnected [CM104005] Call(36): Setup completed for call from Ext.100 to Ln:10000@Sipgate
    11:53:17.763 CallLegImpl::eek:nConnected [CM103001] Call(36): Created audio channel for Ext.100 (84.153.105.xxx:16474) with Media Server (206.71.149.xxx:7064)
    11:53:08.576 CallConf::eek:nProvisional [CM103003] Call(36): Ln:10000@Sipgate is ringing
    11:53:07.451 CallConf::eek:nIncoming [CM103002] Call(36): Incoming call from 100 (Ext.100) to sip:004917620664xxx@206.71.149.xxx
  7. Daikoku
    Sep 22, 2007
    28
    Unfortunately, I still wasn't able to resolve this. Anyone else has an idea?
  8. dyntech
    dyntech New Member
    Mar 28, 2007
    160
    It looks like some sort of network or firewall issue. Somehow the 3CX is losing the IP address of the extension.
  9. Daikoku
    Sep 22, 2007
    28
    Doesn't really make sense to me... when 3cx already has the IP and destination port, why would this be a firewall issue?
    Looks more like a bug to me.
  10. dyntech
    dyntech New Member
    Mar 28, 2007
    160
    Check your "Register Expires" or "Refresh" intervals. I set all of mine to 1800.
    Also check your network is there a lot of traffic? Are you doing QoS in the router? I could just be losing the connection temporarily.
  11. Daikoku
    Sep 22, 2007
    28
    Register expires is set to 1800. Network is not congested at all, no QoS at the router. I think if it would lose the connection it would also lose the port not only the IP?
  12. rolf
    May 6, 2007
    13
    It's and my problem too. I think, that it is a BUG.
  13. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    2,007
    309
    This is a firewall problem. What firewall are you using?
  14. Daikoku
    Sep 22, 2007
    28
  15. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Yes, we have lot of ideas... :)
    First is remove check from "support re-Invites" in sipgate provider configuration.
    Regards
  16. Daikoku
    Sep 22, 2007
    28
    that did it, thanks :)
    It works fine if I put an external call on hold but it doesn't work if I call from one extension to another.
