on hold music, problems with updating
Discussion in '3CX Phone System - General' started by css, Jan 15, 2008.
  1. css
    css
    Aug 15, 2007
    21
    I am currently running version 5.0.3752.0
    I also use SPA 3000
    Since I have update to version 5 I cann't get my on hold music to work. It is just dead air.
    Also when I downloaded the new version of version 5 I was unable to register any of my lines or phones. So I reverted back to the old version would you have any suggestion on that.
    Also how important is it to do the phone provisioning updates. Every sense trying to update to the new version and it not working I have been a little leary of do updates.
    Thanks for any helpful suggestions
  2. kate
    Jan 14, 2008
    18
    I have had the same problem before .
    When I change version v5.0.3752 to v5.03790 ,and then it's working well.
  3. asfuture
    asfuture New Member
    Aug 3, 2007
    156
    you can take a look on http://www.3cx.com/support/buildhistory.html. there in stay that this problems happends if you are using the digitaal receptionist.
