On Hold Music Volume
Discussion in '3CX Phone System - General' started by jpatterson, Sep 10, 2013.
  1. jpatterson
    Jul 30, 2013
    The volume of our on hold music is very loud. Does anyone know of a way to control the volume of on hold music?
    11,095
    327
    If it's a file, then it must me modified externally with audio software, then re-loaded to the PC.
  3. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    We tend to put Audacity on the box.
    Compression will address dynamic volumes, else generally decrease the volume on the default hold by about 11dB.
