on-hook but cannot dial out or recv calls
Discussion in 'Android' started by BAlain, Aug 7, 2011.
  1. BAlain
    Aug 7, 2011
    GT-P1000m
    Froyo 2.2
    3CX for Android
    sip is from ekiga
    number is from Ipkall
    When I run 3CX it registers and the status goes on-hook.
    I can here the tones as I punch in a phone number but nothing happens after that.
    Is this 3CX configuation problems or am I having problems with Ekiga or Ipkall?
    Any help would be great,
    thanks
  2. BAlain
    Aug 7, 2011
    Sorry. I do actually recieve calls, when I try dialing out though it says 'calling' in the status area for a second then returns to 'on-hook'.
  3. speedbit
    Jul 22, 2010
    I have EXACTLY the same problem... anyone who can help on this? :S
  4. StefanW
    Jun 2, 2009
    1,209
    84
    I guess ur Provider stops the call for a reason.
    If you can get in touch with them it would be the best way.
    Or u use a 3CX PBX register the phone to this and then the PBX with the Proivider.
    Then you are able to catch the SIP Messages been exchanged and you have full cotnroll of your voIP inviroment plus many more benefits.
    Free edition of the pbx you can find here: http://www.3cx.com/phone-system/download-phone-system.html
  5. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,476
    67
    @BAlain & speedbit
    Which version of 3CXPhone for Android are you using? :roll:
  6. marmalade
    Sep 23, 2011
    Re: on-hook but cannot dial out but can receive calls
    1.3.1 on Android 2.2.
    Receiving calls works, dialing out doesn't. Unless 3G setup is enabled.
