Solved On Way Audio for outgoing Broadvoice trunk calls
Discussion in '3CX Phone System - General' started by JST, Jan 8, 2017.
  1. JST
    JST New Member
    Jan 8, 2017
    107
    I just installed the free version of 3CX and it seems to work just fine with the exception of making outgoing calls. The trunk is provided by Broadvoice and oddly enough I can receive incoming calls just fine.
    Here is what I have checked so far:
    Sophos Firewall - Confirmed configuration using the 3CX firewall check (PASSED)
    Sophos Firewall - Confirmed port usage during calls to be in valid range (Seems to be OK)
    Incoming Call - Used cell phone to call trunk DID -> Fully works (PASSED)
    Outgoing Call - Called cell phone using trunk -> Cell phone can receive audio, but local phone cannot hear the cell phone (FAILED)
    Codecs - Changed all codecs to the same codec to simplify testing
    Any suggestions? Thank you!
  2. JST
    JST New Member
    Jan 8, 2017
    107
    I found that this issue was caused by the Sophos Firewall and I have resolved it by disabling the built-in VoIP support.
    Hope this will help someone running into the same problem!
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,349
    274
    Thank you for sharing your solution :)
