On Windows 2003 x64
Discussion in '3CX Phone System - General' started by VladislavA, Jul 25, 2007.
  1. VladislavA
    Jun 9, 2007
    30
    I installed 3CX on Windows 2003 x64.
    If I click on "Add PSTN" (or "Add VOIP") then... nothing. Links aren't working.
  2. landfiets
    landfiets New Member
    Jul 17, 2007
    242
    to understand more of your problem maybe you can tell us more about configuration of your computer, and if there's a lot more on the same computer. one tip allready. You can better install the 3CX Phonesystem on a different (virtual)harddisk then the same as where the windows config is.
    A lot of users did that and e'thing was working better.
    Did you open all ports necessary? Do you try to add voip from a different computer in the same network, so remote?
  3. VladislavA
    Jun 9, 2007
    30
    The same bug is on the another computer. I'll create new topic.
  4. Fynskisb16
    Jul 18, 2007
    21
