- Joined
- Aug 19, 2015
- Messages
- 468
- Reaction score
- 388
Thank you for your contribution to the 3CX forums.
We’re updating our login process for all 3CX forums whereby you will be able to login with the same credentials you use for the Partner or Customer Portal.
What does this mean for you? You will no longer have to remember a separate set of logins; just one set of credentials for anything 3CX!
What do you need to do?
And that’s it. Super easy. One Account. All of 3CX.
Regards,
The 3CX Team
- Update the email address you use to login to our forums to make it match that of the Partner/Customer Portal.
- If you do not have a Portal account go ahead and create one here. Make sure to use the same email address as that of the forum.
Regards,
The 3CX Team
