"One button" transfers with IPPBX-possible with 3cx/snom
Discussion in '3CX Phone System - General' started by Anonymous, Jul 24, 2008.
  1. Anonymous
    Anonymous Guest
    Thanks for your continued feedback Matt!
  2. Banana Jack
    Apr 2, 2008
    17
    Thanks, this is a really useful setting to know! Previously it has been pretty annoying and non-intuitative to have to press the transfer button twice after announcing a call to a colleague on our Snom 370 phones.
    Thanks again
    Glenn
  3. Anonymous
    Anonymous Guest
    Hi Matt,
    can you please provide further instructions as to how you set this up? I'm pretty new to SNOM since we normally use only Linksys phones.
    Jonathan
  4. Anonymous
    Anonymous Guest
    Matt,
    that did it - thanks a lot. One other thing - can you pickup a call just by pressing a BLF light? Can't seem to find a way of how to get this working.
    Jon
  5. Anonymous
    Anonymous Guest
    Matt,
    tried that setting but the result is that only the line that rang first will be picked up. My idea was to have a speed dial made of *20* and then pressing one of the BLF lights to pickup that particular light.
    Jon
  6. moon1234
    Jan 25, 2008
    24
    Simulated shared line appearance's can be done by using DID's to a custom extension and then register that button on multiple phones. 3CX can do this via SIP forking. I am not sure if the status information shows up properly. but it should work just fine. I don't think you can barge in though without support at the SIP server.
