One extension is being redirected, can't find where it's programmed
Discussion in '3CX Phone System - General' started by eparker@sara.com, Jul 19, 2016.
  1. eparker@sara.com
    Jan 20, 2016
    5
    I have an extension that is being redirected, but I can't find where that redirection is programmed.
    I call from outside and go to the auto attendant, dial the extension of my conference room, and get redirected
    (IVR (980) replaced by 16195500003) <- From Call Report
    CALL LOG
    19-Jul-2016 13:49:44.645 Call to T:Extn:201@[Dev:sip:201@192.168.1.144:5060] from L:2573.1[Line:10002<<REMOVED FOR PRIVACY] failed, cause: Cause: 302 Moved Temporarily/INVITE from 192.168.1.144:5060
    Any idea what's going on here? Other lines work when dialed from the auto attendant.
    10,744
    281
    What type of set is it. It seems as if there may be an option invoked on the set.
  3. eparker@sara.com
    Jan 20, 2016
    5
  4. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,083
    61
    Look in the manual -
    http://support.polycom.com/global/docum ... _guide.pdf
    Forwarding Calls
    You can set up your phone to forward incoming calls to another party (static
    forwarding), or you can forward a call as your phone rings (dynamic
    forwarding). Your phone will forward calls even if you enable the Do Not
    Disturb Feature.
    You can also reject calls from a particular contact (by sending the call to your
    voice mail system), or divert calls from a particular contact to another party.
    For more information, see Managing Incoming Calls on page 2-23.
    This may be the issue as Leejor suggested.
  5. eparker@sara.com
    Jan 20, 2016
    5
    Finally got the ability to check the actual phone because I temporarily replaced it. You were right some ass-hat had programmed the phone to forward to a number at the phone itself.
    Thank You gents.
