One Grandstream phone playing up...
Discussion in '3CX Phone System - General' started by thames, Dec 2, 2012.
  1. thames
    thames New Member
    Apr 4, 2011
    133
    Hi Folks
    3CX v10 - still to upgrade to 11.
    I have two Grandtream 2100 phones and one Grandstream 2110. One of the 2100s simply will not dial a number I type on the keypad without adding a 0 to it. For example, if I dial 651345 the phone attempts to dial 0651345. None of the other phones are doing this. To be sure, I've checked the settings in Outbound rules but they look to be OK. Ny feeling is that this is coming from the phone rather than from the 3CX system as the other two phones are behaving perfectly.
    Any ideas? This is driving me crazy.
    Cheers
    Chris
  2. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,777
    281
    Factory reset of the phone and then let it reprovision?
  3. thames
    thames New Member
    Apr 4, 2011
    133
    Hi there
    I could do that, I guess. I've been a bit chicken to actually reset the phone in case it screws all the other functions up too! ;)
    Cheers
    Chris
  4. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    Factory reset, upgrade firmware. Before you do that however, check under account 1 what the dialplan string is. I am wondering...
  5. thames
    thames New Member
    Apr 4, 2011
    133
    Hey Sigma1
    Apologies - I appear to have duplicated the '0' thread. Resolved it this morning - found a pesky '0' in the dialplan on the phone under account number 1.
    Many thanks for your help as always.
    Chris
