One way audio after few minutes
Discussion in '3CX Phone System - General' started by Joostsoo, Aug 8, 2014.
  1. Joostsoo
    Aug 8, 2014
    Hello
    I have a problem with a new installation.
    When I make a call all works well until after a few minutes the party on the other end does not longer hear me.
    I hear him perfect.
    Somebody seen tis behavior?
    Second question would be, how to bedug it
    I hope someone can help
    Thank, Joost
  2. uptime1
    uptime1 New Member
    Jan 13, 2012
    112
    30
    Sounds like an intervening firewall or router is dropping RTP packets after timing out the port(s). Check the log files of the devices, better yet, get a packet trace.
  3. bardissi
    bardissi Member
    Jan 31, 2012
    318
    agreed sounds like a firewall problem
  4. complex1
    complex1 Active Member
    Jan 25, 2010
    814
    49
    Have you forwarded the correct ports
    Check if SIP_ALG is disabled
    After installation have you run the firewall checker?
    Enable the option “Enable Keep Alives” in Settings > General > Global Options
  5. Joostsoo
    Aug 8, 2014
    Hello
    Thanks for your responses.
    I did run the firewall checker and all test show that it is ok.
    May be I 'm wrong here but it works at first but stops working after a minute or 3.
    Then I can no longer hear the other party.
    It is always so that I lose the sound no matter who makes the call.
    To morrow I will try to make a Wireshark trace.
    Thanks so far
  6. joostsoontiens
    Aug 16, 2014
    I added a wireshark trace and the activity log.
    Maybe someone will look into this
    I'm not very good in reading traces
    Thanks in advance for you help
    Regards joost
