One Way Audio, External Callers cannot hear me
Discussion in '3CX Phone System - General' started by zoomzoomvince, Aug 26, 2008.
  1. zoomzoomvince
    Jul 31, 2008
    19
    I have my 3CX system installed now and I can receive inbound calls with one slight hitch. I can hear the external caller talking but they cannot hear me. I can make outbound calls perfectly. I couldn't see anything obvious in the 3CX server status screen so I turned on verbose logging and done a quick test and this is the result. I am using VOIPon by the way and Linksys SPA942 handsets. I thought it might be the firmware on the SPA942 which was v5.1.15(a) so I upgraded them to the latest version without any change.
    14:01:22.167 Call::Terminate [CM503008]: Call(485): Call is terminated
    14:01:22.167 LineCfg::getInboundTarget [CM503012]: Inbound office hours' rule for LN:10000 forwards to DN:8000
    14:01:22.167 LineCfg::getInboundTarget Looking for inbound target: called=08713091822; caller=07970206489
    14:01:12.011 LineCfg::getInboundTarget [CM503012]: Inbound office hours' rule for LN:10000 forwards to DN:8000
    14:01:12.011 LineCfg::getInboundTarget Looking for inbound target: called=08713091822; caller=07970206489
    14:01:12.011 Call::Terminate [CM503008]: Call(485): Call is terminated
    14:01:11.995 LineCfg::getInboundTarget Looking for inbound target: called=08713091822; caller=07970206489
    14:00:50.026 CallCtrl::eek:nLegConnected [CM503007]: Call(485): Device joined: sip:1462@192.168.1.48:5060
    14:00:50.026 LineCfg::getInboundTarget [CM503012]: Inbound office hours' rule for LN:10000 forwards to DN:8000
    14:00:50.026 LineCfg::getInboundTarget Looking for inbound target: called=08713091822; caller=07970206489
    14:00:49.995 CallCtrl::eek:nLegConnected [CM503007]: Call(485): Device joined: sip:07970206489@192.168.1.1:5060
    14:00:49.870 MediaServerReporting::SetRemoteParty [MS210003] C:485.1:Answer provided. Connection(transcoding mode):82.108.156.100:9016(9017)
    14:00:49.870 MediaServerReporting::SetRemoteParty [MS210001] C:485.5:Answer received. RTP connection: 192.168.1.48:16476(16477)
    14:00:49.870 Extension::printEndpointInfo [CM505001]: Ext.1462: Device info: Device Identified: [Man: Linksys;Mod: SPA-941;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA942-5.2.8] Transport: [sip:192.168.1.225:5060]
    14:00:49.870 CallLeg::setRemoteSdp Remote SDP is set for legC:485.5
    14:00:49.870 CallCtrl::eek:nAnsweredCall [CM503002]: Call(485): Alerting sip:1462@192.168.1.48:5060
    14:00:48.401 CallLeg::eek:nFailure [CM503003]: Call(485): Call to sip:1470@192.168.1.225 has failed; Cause: 486 Busy Here; from IP:192.168.1.38:5060
    14:00:48.386 MediaServerReporting::SetRemoteParty [MS210002] C:485.9:Offer provided. Connection(transcoding mode): 192.168.1.225:7204(7205)
    14:00:48.386 CallLeg::eek:nFailure [CM503003]: Call(485): Call to sip:1461@192.168.1.225 has failed; Cause: 486 Busy Here; from IP:192.168.1.49:5060
    14:00:48.354 MediaServerReporting::SetRemoteParty [MS210002] C:485.8:Offer provided. Connection(transcoding mode): 192.168.1.225:7202(7203)
    14:00:48.323 MediaServerReporting::SetRemoteParty [MS210002] C:485.7:Offer provided. Connection(transcoding mode): 192.168.1.225:7200(7201)
    14:00:48.307 MediaServerReporting::SetRemoteParty [MS210002] C:485.6:Offer provided. Connection(transcoding mode): 192.168.1.225:7198(7199)
    14:00:48.276 MediaServerReporting::SetRemoteParty [MS210002] C:485.5:Offer provided. Connection(transcoding mode): 192.168.1.225:7196(7197)
    14:00:48.261 MediaServerReporting::SetRemoteParty [MS210002] C:485.4:Offer provided. Connection(transcoding mode): 192.168.1.225:7194(7195)
    14:00:48.229 MediaServerReporting::SetRemoteParty [MS210002] C:485.3:Offer provided. Connection(transcoding mode): 192.168.1.225:7192(7193)
    14:00:48.214 MediaServerReporting::SetRemoteParty [MS210002] C:485.2:Offer provided. Connection(transcoding mode): 192.168.1.225:7190(7191)
    14:00:48.182 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(485): Calling: RingAll8000:1459Ext.14591460Ext.14601461Ext.14611462Ext.14621467Ext.14671470Ext.14701455Ext.14551454Ext.14541452Ext.1452@[Dev:sip:1459@192.168.1.43:5060, Dev:sip:1460@192.168.1.47:5060, Dev:sip:1461@192.168.1.49:5060, Dev:sip:1462@192.168.1.48:5060, Dev:sip:1467@192.168.1.44:5060, Dev:sip:1470@192.168.1.38:5060, Dev:sip:1455@192.168.1.55:5060, Dev:sip:1454@192.168.1.45:5060]
    14:00:48.182 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:8000@192.168.1.225:5060]
    14:00:48.182 MediaServerReporting::SetRemoteParty [MS210000] C:485.1:Offer received. RTP connection: 192.168.1.1:10250(10251)
    14:00:48.182 CallLeg::setRemoteSdp Remote SDP is set for legC:485.1
    14:00:48.182 Line::printEndpointInfo [CM505003]: Provider:[VOIPon] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Asterisk PBX] Transport: [sip:192.168.1.225:5060]
    14:00:48.182 LineCfg::getInboundTarget [CM503012]: Inbound office hours' rule for LN:10000 forwards to DN:8000
    14:00:48.182 LineCfg::getInboundTarget Looking for inbound target: called=08713091822; caller=07970206489
    14:00:48.151 CallCtrl::eek:nIncomingCall [CM503001]: Call(485): Incoming call from 07970206489@(Ln.10000@VOIPon) to [sip:8000@192.168.1.225:5060]
    14:00:46.917 LineCfg::getInboundTarget [CM503012]: Inbound office hours' rule for LN:10000 forwards to DN:8000
    14:00:46.901 LineCfg::getInboundTarget Looking for inbound target: called=08713091822; caller=07970206489
    14:00:46.901 CallLeg::eek:nNewCall [CM500002]: Info on incoming INVITE:
    INVITE sip:08713091822@82.108.156.100 SIP/2.0
    Via: SIP/2.0/UDP 192.168.1.1:5060;branch=z9hG4bK7d7bce07;rport=5060
    Max-Forwards: 70
    Contact: [sip:07970206489@192.168.1.1:5060]
    To: [sip:08713091822@82.108.156.100]
    From: "07970206489"[sip:07970206489@77.240.48.141];tag=as1caa5e2c
    Call-ID: 64342f7d2637ec1319359fe167fc1f26@77.240.48.141
    CSeq: 102 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY
    Date: Tue, 26 Aug 2008 13:54:18 GMT
    Supported: replaces
    User-Agent: Asterisk PBX
    Content-Length: 0
    I also changed the extensions and put a tick in the 'pbx delivers audio' section without any change.
  2. galal202
    galal202 New Member
    Jun 23, 2008
    235
    What is your external devices
    or voip providers
  3. zoomzoomvince
    Jul 31, 2008
    19
    I am using VOIPon as my provider. My firewall is a zyxel Zywall USG-200 which has passed the firewall test ok.
  4. galal202
    galal202 New Member
    Jun 23, 2008
    235
    hello,
    change stun server in 3cx and your ip phone
  5. zoomzoomvince
    Jul 31, 2008
    19
    This is what I have got in the 3CX General Settings
    Default STUN server address: stun.3cx.com Port 3478
    Default second STUN server address: stun.xten.com Port 3478
    Timeout time for STUN response (ms) 3000
    Recheck external IP every (sec) 1200
    On the Linksys SPA942 the "Stun Enable" was set to no. I enabled it and set the server to stun.3cx.com. Makes no difference.
  6. galal202
    galal202 New Member
    Jun 23, 2008
    235
    try other stun servers
    did you istalled 3cx on a fresh xp
    if you can reinstall every thing
    reset your linksys to factory set and set again
    did you used the auto-provisioning
