one way audio in 3CXphone
Discussion in 'Windows' started by sfgarcia79, Jul 9, 2010.
  1. sfgarcia79
    Jul 9, 2010
    hello,
    i have quesion i'm working with the 3CXPhone on my laptop and also all my colleags are working with it.
    but i have a problem with the audio. when i dail a telephone # the people on the other end of the line can't hear me.
    i can hear them but not the otherway around.
    what can this be? it's really iritating bucause we can't use it now.
    even when we switch off the firewall it still doesn't work.
    i hope someone can help me.
    thanks
    Sebastian
  2. zman574
    Jun 24, 2010
    57
    Are you connected to the LAN or are you on a remote site. Are you using the tunell? Do you have port forwarding set up correctly?
  3. leejor
    11,105
    329
    Could it be your Mic? Does it work in other applications?
  4. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,557
    118
    Can you confirm this with another microphone?
  5. sfgarcia79
    Jul 9, 2010
    thanks for all your reply's
    but what solved the problem was de install version 9 totaly.
    and then install the version 8 phone and then install the version 9 assistant and it works.
    i don't have the problem anymore.
    regards
    Sebastian
