One-way audio in tunnel w/hardphone
Discussion in '3CX Phone System - General' started by Ryandc, Jun 27, 2008.
  1. Ryandc
    Aug 13, 2007
    70
    Okay, I got the tunnel up and working with the latest version of 3cx. I'm using a VOIP client build I downloaded today. Using the tunnel, I can connect to the 3cx server from a remote location, and I can proxy the phone to it. Using the proxied hardphone through the tunnel, I can make calls and get two-way audio without any problem. However, when I attempt to call TO the proxied phone, I end up being able to receive audio on the proxied phone (but cannot transmit audio); the phone is stuck on "answering," and after the SIP response timout (in my case, ~30 seconds), the connection hangs up.
    I did a wireshark packet inspection, and there was tons of garbage data moving from the SIP tunnel to the computer proxy. Here's a sample:
    Unknown request: \355\002\022\375Sip0ACK sip:407@192.168.1.100:5060
    Here's what the verbose server logs look like when I make a call to that extension:
    21:38:38.252 MediaServerReporting::RTPReceiver [MS105000] C:50.3: No RTP packets were received:remoteAddr=127.0.0.1:10248,extAddr=0.0.0.0:0,localAddr=127.0.0.1:7110
    21:38:38.252 Call::Terminate [CM503008]: Call(50): Call is terminated
    21:38:38.252 LineCfg::getInboundTarget [CM503012]: Inbound out-of-office hours' rule for LN:10019 forwards to DN:302
    21:38:38.190 LineCfg::getInboundTarget [CM503012]: Inbound out-of-office hours' rule for LN:10019 forwards to DN:302
    21:38:38.174 Call::Terminate [CM503008]: Call(50): Call is terminated
    21:38:38.174 LineCfg::getInboundTarget [CM503012]: Inbound out-of-office hours' rule for LN:10019 forwards to DN:302
    21:38:22.455 MediaServerReporting::SetRemoteParty [MS210001] C:49.1:Answer received. RTP connection: 192.168.0.1:16528(16529)
    21:38:22.455 CallLeg::setRemoteSdp Remote SDP is set for legC:50.5
    21:38:22.455 Call::Terminate [CM503008]: Call(49): Call is terminated
    21:38:22.346 MediaServerReporting::SetRemoteParty [MS210002] C:49.1:Offer provided. Connection(transcoding mode): 192.168.0.12:9014(9015)
    21:38:22.346 Call::Terminate [CM503008]: Call(49): Call is terminated
    21:38:22.346 LineCfg::getInboundTarget [CM503012]: Inbound out-of-office hours' rule for LN:10019 forwards to DN:302
    21:38:22.252 LineCfg::getInboundTarget [CM503012]: Inbound out-of-office hours' rule for LN:10019 forwards to DN:302
    21:38:22.237 CallLeg::eek:nRefer Relpaces: MTZjNzg4ZjlmMjhiODNmYzIyMGQ1MWYzM2FlODE1ZWQ.;to-tag=80026279;from-tag=5e1a105e
    21:38:22.237 CallLeg::eek:nRefer Refer: from="CROMPTON,RYAN"[sip:8013181491@127.0.0.1:5060];tag=984ffc36; to=[sip:407@127.0.0.1:5060];tag=680d784c; RefTo="CROMPTON,RYAN"[sip:8013181491@127.0.0.1:5060?Replaces=MTZjNzg4ZjlmMjhiODNmYzIyMGQ1MWYzM2FlODE1ZWQ.%3Bto-tag%3D80026279%3Bfrom-tag%3D5e1a105e];tag=80026279
    21:38:22.237 CallLeg::eek:nConfirmed Session 27780 of leg C:50.1 is confirmed
    21:38:22.096 CallCtrl::eek:nLegConnected [CM503007]: Call(50): Device joined: sip:407@192.168.1.100:5060
    21:38:22.018 MediaServerReporting::SetRemoteParty [MS210001] C:50.3:Answer received. RTP connection: 127.0.0.1:10248(10249)
    21:38:22.018 Extension::printEndpointInfo [CM505001]: Ext.407: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA922-5.2.8] Transport: [sip:192.168.0.12:5060]
    21:38:22.018 CallLeg::setRemoteSdp Remote SDP is set for legC:50.3
    21:38:22.018 CallCtrl::eek:nAnsweredCall [CM503002]: Call(50): Alerting sip:407@192.168.1.100:5060
    21:38:19.330 Extension::printEndpointInfo [CM505001]: Ext.407: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX_VoIP_Client] Transport: [sip:192.168.0.12:5060]
    21:38:19.330 CallCtrl::eek:nAnsweredCall [CM503002]: Call(50): Alerting sip:407@127.0.0.1:5070;rinstance=1b0fa01881287341
    21:38:18.737 MediaServerReporting::SetRemoteParty [MS210002] C:50.4:Offer provided. Connection(transcoding mode): 127.0.0.1:7112(7113)
    21:38:18.674 MediaServerReporting::SetRemoteParty [MS210002] C:50.3:Offer provided. Connection(transcoding mode): 127.0.0.1:7110(7111)
    21:38:18.643 MediaServerReporting::SetRemoteParty [MS210002] C:50.2:Offer provided. Connection(transcoding mode): 127.0.0.1:7108(7109)
    21:38:18.596 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(50): Calling: Shared:Ext.407@[Dev:sip:407@127.0.0.1:5070;rinstance=1b0fa01881287341, Dev:sip:407@192.168.1.100:5060, Dev:sip:407@192.168.1.115:5060]
    21:38:18.596 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:407@127.0.0.1:5060]
    21:38:18.471 CallCtrl::eek:nIncomingCall [CM503001]: Call(50): Incoming call from Ext.302 to [sip:407@127.0.0.1:5060]
    21:38:18.471 CallLeg::eek:nNewCall [CM500002]: Info on incoming INVITE:
    INVITE sip:407@127.0.0.1:5060 SIP/2.0
    Via: SIP/2.0/UDP 127.0.0.1:40600;branch=z9hG4bK-d8754z-b17a6765950bae62-1---d8754z-;rport=40600
    Max-Forwards: 70
    Contact: [sip:302@127.0.0.1:40600]
    To: [sip:407@127.0.0.1:5060]
    From: "CROMPTON,RYAN"[sip:8013181491@127.0.0.1:5060];tag=984ffc36
    Call-ID: ZDQxZTM4Mzk2YTMyY2I0MmRkODA1OGE3ZmM3MWE3NzI.
    CSeq: 2 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO
    Proxy-Authorization: Digest username="302",realm="3CXPhoneSystem",nonce="12859011497:6f64201d1935f631f632e9d3c0bb5835",uri="sip:407@127.0.0.1:5060",response="0dfa1e16f0ce58d01400d7a79af39739",algorithm=MD5
    Supported: replaces
    User-Agent: 3CX IVR
    Content-Length: 0
    21:38:07.580 CallLeg::eek:nConfirmed Session 27740 of leg C:49.1 is confirmed
    21:38:07.487 CallCtrl::eek:nLegConnected [CM503007]: Call(49): Device joined: sip:302@127.0.0.1:40600;rinstance=2030f222e60fbc25
    21:38:07.487 LineCfg::getInboundTarget [CM503012]: Inbound out-of-office hours' rule for LN:10019 forwards to DN:302
    21:38:07.424 CallCtrl::eek:nLegConnected [CM503007]: Call(49): Device joined: sip:8012247199@192.168.0.1:5060
    21:38:07.424 MediaServerReporting::SetRemoteParty [MS210005] C:49.1:Answer provided. Connection(proxy mode):192.168.0.12:9014(9015)
    21:38:07.424 MediaServerReporting::SetRemoteParty [MS210001] C:49.2:Answer received. RTP connection: 127.0.0.1:40610(40611)
    21:38:07.424 CallLeg::setRemoteSdp Remote SDP is set for legC:49.2
    21:38:07.424 Extension::printEndpointInfo [CM505001]: Ext.302: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX IVR] Transport: [sip:127.0.0.1:5060]
    21:38:07.424 CallCtrl::eek:nAnsweredCall [CM503002]: Call(49): Alerting sip:302@127.0.0.1:40600;rinstance=2030f222e60fbc25
    21:38:06.955 MediaServerReporting::SetRemoteParty [MS210004] C:49.2:Offer provided. Connection(proxy mode): 127.0.0.1:7106(7107)
    21:38:06.924 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(49): Calling: Ext:Ext.302@[Dev:sip:302@127.0.0.1:40600;rinstance=2030f222e60fbc25]
    21:38:06.924 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:302@64.50.120.38:5060]
    21:38:06.924 MediaServerReporting::SetRemoteParty [MS210000] C:49.1:Offer received. RTP connection: 192.168.0.1:16528(16529)
    21:38:06.924 CallLeg::setRemoteSdp Remote SDP is set for legC:49.1
    21:38:06.924 Line::printEndpointInfo [CM505003]: Provider:[Veracity] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] Transport: [sip:192.168.0.12:5060]
    21:38:06.924 LineCfg::getInboundTarget [CM503012]: Inbound out-of-office hours' rule for LN:10019 forwards to DN:302
    21:38:06.705 CallCtrl::eek:nIncomingCall [CM503001]: Call(49): Incoming call from 8013181491@(Ln.10019@Veracity) to [sip:302@64.50.120.38:5060]
    21:38:06.705 MediaServerReporting::STUN [MS101003] C:49.1: Possible firewall problem. Address mapping failed on STUN server 192.168.0.12:3478 for local address ":9014"
    21:38:00.549 LineCfg::getInboundTarget [CM503012]: Inbound out-of-office hours' rule for LN:10019 forwards to DN:302
    Any ideas?
    Other notes: I'm using a SPA-922 as my hardphone. I also tried this with a GRandstream Budgetone, and both exhibited the same behavior. One thing I did have to do with both, however, was set the proxy IP to computer proxy IP port 5080. If I didn't do this, the phones wouldn't register at all.
    Recap: Proxied phone can make calls. When calls are made TO proxied phone, phone rings, I can pick up receiver, but phone only displays "Answering" until SIP timeout is reached, and session is terminated.
    I'll closs-post this in a couple places, but let me know what you guys need... I'm eager to get our telecommuting solution available, specially with gas prices being what they are!
    -Ryan
