One Way Audio, IP change
Discussion in '3CX Phone System - General' started by TSDKen, Jan 4, 2016.
  1. TSDKen
    Sep 29, 2008
    33
    I came back from the holidays and I now have one way audio on a v14 sp2 install of 3CX. My IP number had changed so I updated in the 3CX network settings. Internally everything works fine. I have restarted all the phones/servers several times and I am still experiencing problems. I talked to NexVortex tech support and it appears that my old IP # is still making to their servers. Is there a cache I need to clear out? Any other places I need to update the IP number other than Settings>Network>Public IP
    Thanks for the help.
    Ken Bell
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,586
    309
    Check thru the custom parameter page. This method however is not supported.
    As far as I know the recommended way to update the IP is Backup -> Uninstall -> Reinstall.
    Upon setup before restoring, it will ask for Public IP Address.
  3. CentrexJ
    CentrexJ Member
    May 5, 2009
    466
    77
    You can check under the sip trunk, advanced tab, registration settings, set "use this IP address" and put in your new IP.
    Realistically though you are best to do as Craig said and backup, uninstall and re-install and use the new IP settings, then import your backup.
  4. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,386
    88
    There is a thread about this here as well: http://www.3cx.com/forums/incorrect-external-ip-address-in-sdp-43357.html
