- Joined
- Mar 7, 2008
- Messages
- 35
- Reaction score
- 0
I know a lot of probs with one way audio due to firewall, but I really think mine is set up OK and am non-plussed. After recent upgrade to version 6.1 people can no longer hear me, but I can hear them. This is the set up:
3cx running on windows XP behind linksys wag325n router. ports 9000-9015 and 5060-5065 mapped to 3cx server pc.
voiptalk set up as voip provider
speedtouch 760wl used as analog ATA FXS with local ip 192.168.0.50
linkssys spa3102 used as FXO gateway to PSTN with locak ip 192.168.0.40
I can call between internal extensions no problem.
I can call via the linksys spa3102 no problem.
When I make a call over voiptalk I can hear remote party but they can't hear me.
I have tried using PBX delivers audio on the voiptalk line setting, but does not work either.
My Firewall test completes successfully.
From the logs it looks like call is set up OK, but I don't know what is then happening to the RTP streams.
Here is sample log of setting up a call:
10:56:41.187 Call::Terminate [CM503008]: Call(1): Call is terminated10:56:41.187 Call::Terminate [CM503008]: Call(1): Call is terminated
10:56:23.750 CallLeg:nConfirmed Session 59 of leg C:1.1 is confirmed
10:56:23.640 CallCtrl:nLegConnected [CM503007]: Call(1): Device joined: sip:[email protected]:5060
10:56:23.640 MediaServerReporting::SetRemoteParty [MS210001] C:1.2:Answer received. RTP connection: 77.240.48.201:49030(49031)
10:56:23.640 CallLeg::setRemoteSdp Remote SDP is set for legC:1.2
10:56:20.546 MediaServerReporting::SetRemoteParty [MS210005] C:1.1:Answer provided. Connection(proxy mode):192.168.0.12:7100(7101)
10:56:20.546 MediaServerReporting::SetRemoteParty [MS210001] C:1.2:Answer received. RTP connection: 77.240.48.209:49030(49031)
10:56:20.546 CallLeg::setRemoteSdp Remote SDP is set for legC:1.2
10:56:20.546 Line:rintEndpointInfo [CM505003]: Provider:[voiptalk] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] Transport: [sip:192.168.0.12:5060]
10:56:20.546 CallCtrl:nAnsweredCall [CM503002]: Call(1): Alerting sip:[email protected]:5060
10:56:17.968 MediaServerReporting::SetRemoteParty [MS210004] C:1.2:Offer provided. Connection(proxy mode): 80.229.82.249:9000(9001)
10:56:17.796 CallCtrl:nSelectRouteReq [CM503004]: Call(1): Calling: VoIPline:01565889108@(Ln.10001@voiptalk)@[Dev:sip:[email protected]:5060]
10:56:17.765 CallCtrl:nSelectRouteReq [CM503010]: Making route(s) to "889108"[sip:[email protected]:5060]
10:56:17.765 MediaServerReporting::SetRemoteParty [MS210000] C:1.1:Offer received. RTP connection: 192.168.0.50:7302(7303)
10:56:17.765 CallLeg::setRemoteSdp Remote SDP is set for legC:1.1
10:56:17.765 Extension:rintEndpointInfo [CM505001]: Ext.11: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [SpeedTouch 780] Transport: [sip:192.168.0.12:5060]
10:56:17.750 CallCtrl:nIncomingCall [CM503001]: Call(1): Incoming call from Ext.11 to "889108"[sip:[email protected]:5060]
10:56:17.750 CallLeg:nNewCall [CM500002]: Info on incoming INVITE:INVITE sip:[email protected];transport=UDP SIP/2.0Via: SIP/2.0/UDP 192.168.0.50:5060;branch=z9hG4bK-33a581-c9be81d2-66cc2c2cMax-Forwards: 70Contact: [sip:[email protected]:5060;transport=UDP]To: "889108"[sip:[email protected]:5060]From: "Dom desk"[sip:[email protected]:5060];tag=80ad3718-c0a80032-13c4-33a581-5fbdf1ae-33a581Call-ID: [email protected]: 2 INVITESession-Expires: 120Min-SE: 90Allow: INVITE, ACK, BYE, REFER, NOTIFY, CANCEL, OPTIONSProxy-Authorization: Digest username="11",realm="3CXPhoneSystem",nonce="12872429777:7ceddc750d634dbb1bfda59679e0c38d",uri="sip:[email protected];transport=UDP",response="f00d6365215aa125129ef7f40500cb6d",algorithm=MD5Supported: replaces, 100rel, timerUser-Agent: SpeedTouch 780Content-Length: 0X-Serialnumber: CP0737JT3MK
and hear is media server trace:
10:56:17.750|.\MediaServer.cpp(533)|Trace5||??:EndPoint created: (destination=192.168.0.50)
EndPoint: ID=00000041@(LOCAL)
LOGID=C:1.1 Status: MSEP_LOCAL
RTP:192.168.0.12:7100
RTCP:192.168.0.12:7101
STUN RTP:0.0.0.0:0
STUN RTCP:0.0.0.0:0
Coder:
NOT SET
101:telephony-event
Party ptime:20
Party RTP:0.0.0.0:0
Party RTCP:0.0.0.0:0
Decoders:
<empty>
10:56:17.750|.\MediaServer.cpp(979)|Trace5||??:EP 00000041@ joined to call 1
10:56:17.750|.\MediaServer.cpp(988)|Trace5||??:starting send on new call 1
10:56:17.765|.\MediaServer.cpp(630)|Trace5||??:Set Party EP:C:1.1SDP:v=0
o=780 1227956602 1227956602 IN IP4 192.168.0.50
s=-
c=IN IP4 192.168.0.50
t=0 0
m=audio 7302 RTP/AVP 0 8 18 4
a=ptime:20
a=SilenceSuppff
10:56:17.765|.\MSEndPoint.cpp(2441)|Trace5||??:New state00000041@ SILENCE
10:56:17.765|.\MSEndPoint.cpp(1457)|Log2||??:[MS210000] C:1.1:Offer received. RTP connection: 192.168.0.50:7302(7303)
10:56:17.968|.\MSEndPoint.cpp(824)|Trace5||??:Source ports: 9000 STUN RTP:80.229.82.249:9000 RTCP:80.229.82.249:9001 mapped to 80.229.82.249, ports 9000,9001
10:56:17.968|.\MediaServer.cpp(533)|Trace5||??:EndPoint created: (destination=voiptalk.org)
EndPoint: ID=00000042@(EXTERNAL)
LOGID=C:1.2 Status: MSEP_STUN
STUN RTCP:80.229.82.249:9001
Coder:
NOT SET
101:telephony-event
Party ptime:20
Party RTP:0.0.0.0:0
Decoders:
<empty>
10:56:17.968|.\MediaServer.cpp(979)|Trace5||??:EP 00000042@ joined to call 1
10:56:17.968|.\MediaServer.cpp(1024)|Trace5||??:EndPoint 00000042@ removed from call 1
10:56:17.968|.\MSEndPoint.cpp(2441)|Trace5||??:New state00000042@ SILENCE
10:56:17.968|.\MSEndPoint.cpp(1180)|Log2||??:[MS210004] C:1.2:Offer provided. Connection(proxy mode): 80.229.82.249:9000(9001)
10:56:17.968|.\MediaServer.cpp(568)|Trace5||??:Get Local SDP. EP:C:1.2SDP:v=0
o=3cxPS 273082744832 139435442177 IN IP4 80.229.82.249
s=3cxPS Audio call
c=IN IP4 80.229.82.249
t=0 0
m=audio 9000 RTP/AVP 0 8 18 4
a=ptime:20
a=SilenceSuppff
10:56:20.546|.\MediaServer.cpp(979)|Trace5||??:EP 00000042@ joined to call 1
10:56:20.546|.\MediaServer.cpp(630)|Trace5||??:Set Party EP:C:1.2SDP:v=0
o=root 3842 3842 IN IP4 77.240.48.207
s=session
c=IN IP4 77.240.48.209
t=0 0
m=audio 49030 RTP/AVP 8 0 18 4
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:4 G723/8000
a=fmtp:4 annexa=no
a=silenceSuppff - - - -
a=ptime:20
a=sendrecv
a=nortpproxy:yes
10:56:20.546|.\MSEndPoint.cpp(2441)|Trace5||??:New state00000042@ SILENCE
10:56:20.546|.\MSEndPoint.cpp(2441)|Trace5||??:New state00000042@ PASSTHROUGH
10:56:20.546|.\MSEndPoint.cpp(1462)|Log2||??:[MS210001] C:1.2:Answer received. RTP connection: 77.240.48.209:49030(49031)
10:56:20.546|.\MSEndPoint.cpp(2441)|Trace5||??:New state00000041@ PASSTHROUGH
10:56:20.546|.\MSEndPoint.cpp(1185)|Log2||??:[MS210005] C:1.1:Answer provided. Connection(proxy mode):192.168.0.12:7100(7101)
10:56:20.546|.\MediaServer.cpp(568)|Trace5||??:Get Local SDP. EP:C:1.1SDP:v=0
o=3cxPS 43989860352 346667614209 IN IP4 192.168.0.12
s=3cxPS Audio call
c=IN IP4 192.168.0.12
t=0 0
m=audio 7100 RTP/AVP 8 0 18 4
a=fmtp:18 annexb=no
a=fmtp:4 annexa=no
a=ptime:20
a=sendrecv
a=nortpproxy:yes
10:56:23.640|.\MediaServer.cpp(630)|Trace5||??:Set Party EP:C:1.2SDP:v=0
o=root 3842 3843 IN IP4 77.240.48.201
s=session
c=IN IP4 77.240.48.201
t=0 0
a=fmtp:18 annexb=no
a=fmtp:4 annexa=no
a=ptime:20
a=sendrecv
a=nortpproxy:yes
10:56:23.640|.\MSEndPoint.cpp(2441)|Trace5||??:New state00000042@ SILENCE
10:56:23.640|.\MSEndPoint.cpp(2441)|Trace5||??:New state00000042@ PASSTHROUGH
10:56:23.640|.\MSEndPoint.cpp(1462)|Log2||??:[MS210001] C:1.2:Answer received. RTP connection: 77.240.48.201:49030(49031)
10:56:41.171|.\MediaServer.cpp(1024)|Trace5||??:EndPoint 00000041@ removed from call 1
10:56:41.187|.\MediaServer.cpp(1024)|Trace5||??:EndPoint 00000042@ removed from call 1
10:56:41.187|.\MediaServer.cpp(783)|Trace5||??:references to EndPoint 00000041@ were removed
10:56:41.187|.\RTPReceiver.cpp(127)|Trace5||??:Endpoint for socket 924 is not found!
10:56:41.187|.\MSEndPoint.cpp(672)|Trace5||??:EndPoint 00000041@ destroyed
10:56:41.343|.\MediaServer.cpp(783)|Trace5||??:references to EndPoint 00000042@ were removed
10:56:41.343|.\RTPReceiver.cpp(127)|Trace5||??:Endpoint for socket 1004 is not found!
10:56:41.343|.\MSEndPoint.cpp(672)|Trace5||??:EndPoint 00000042@ destroyed
10:56:41.359|.\MediaServer.cpp(1102)|Trace5||??:references to call 1 were removed
10:56:41.359|.\MSCallConf.cpp(33)|Trace5||??:Call: 1 destroyed
STUN RTP:0.0.0.0:0
STUN RTCP:0.0.0.0:0
Coder:
NOT SET
101:telephony-event
Party ptime:20
Party RTP:0.0.0.0:0
Decoders:
<empty>
s=-
t=0 0
a=ptime:20
a=SilenceSuppff
Coder:
NOT SET
101:telephony-event
Party ptime:20
Party RTP:0.0.0.0:0
Decoders:
<empty>
s=3cxPS Audio call
t=0 0
a=ptime:20
a=SilenceSuppff
s=session
t=0 0
a=fmtp:18 annexb=no
a=fmtp:4 annexa=no
a=ptime:20
a=sendrecv
a=nortpproxy:yes
s=3cxPS Audio call
t=0 0
a=fmtp:18 annexb=no
a=fmtp:4 annexa=no
a=ptime:20
a=sendrecv
a=nortpproxy:yes
s=session
t=0 0
a=fmtp:18 annexb=no
a=fmtp:4 annexa=no
a=ptime:20
a=sendrecv
a=nortpproxy:yes
