One way audio on HT-503 grandstream and 3CX VoIP Client
Discussion in '3CX Phone System - General' started by dnwklin, Feb 2, 2009.
  1. dnwklin
    Feb 2, 2009
    10
    One way audio on HT-486 grandstream. When I use Grandstream/X-Lite to place a call, only the other party can hear me. I cannot hear any sound? What is the problem? Thanks
    {UPDATED}
    log: (Called by HT-503 & Close the STUN)
  2. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    Re: One way audio on HT-486 grandstream
    Can you please give more information on your setup. Is XLite on the same LAN as the 3CX server or on a separate network?
    If on the same network please ensure that STUN is disabled. STUN needs to be enabled only if the phone is external to the 3CX server network. see http://www.3cx.com/sip-phones/x-lite.html
  3. dnwklin
    Feb 2, 2009
    10
    I had already disable the stun and all firewalls. The HT-486 and x-lite are on the same LAN. I just started to use the system, I am not sure what kinds of information should I also posted here. Could someone give me more specific instructions? Thank you
  4. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,528
    71
    From the phone(s) which has no incoming audio, try first dial 999 and see if you hear it (sounds nice "see" when about "hearing" :mrgreen: )
  5. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    "Forum rules - Read to get answers" (It is the second line in the "TOPICS" part)
    direct link is http://www.3cx.com/forums/forum-rules-read-to-get-answers-93.html
    Picture attached.
    P.S. Verbose level version of 3CXMediaServer.trace.log may highlight problem.
  6. dnwklin
    Feb 2, 2009
    10
    The following is the log.
