One way audio on internal WIFI
Discussion in 'iOS' started by Andy Wright, Feb 15, 2017.
  1. Andy Wright
    Feb 15, 2017
    Hi all
    Device Info
    Phone Model: [iPhone]
    Generation: [5S, 6, 6S, 7]
    Firmware Version: [10.2]
    Jailbreak: [NO]
    Cydia Installed: [NO]
    Issue Info
    Handset: [Phone|
    Contacts: [Local]
    Connection: [WiFi]
    Server: [Internal]
    I have a very strange one that's bugging me. The Desktop app and desk phones are all working perfectly but the IOS app has a one-way (they can hear me but I can't hear them) audio issue when on the internal WIFI. When I disable WIFI on the phone, switching to 3G or even on an external WIFI they work perfectly. It seems to be restricted to the office.
    I have the extension set to PBX delivers Audio and like I said, everything works fine except this.
    Has anyone else seen this before who can offer any advice?
    #1 Andy Wright, Feb 15, 2017
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,416
    61
    Hi Andy
    Can you please do the following test for me?
    Go to the Settings/Accounts/account settings and delete/clear the "External PBX IP", then back to Accounts, back to Settings and tap Register. Now its should not register on 3G or externa WiFi, but only on internal WiFi. Please tell us if it behaves like this and also if the audio issue still persist. Also, please tell us the PBX version (V14 or V15) and iOS client version (as in Settings/ About)
    vali
    P.S After the test, to restore the deleted "External PBX IP", in Settings tap Re-Provision.
  3. DSXDATA
    DSXDATA New Member
    Oct 20, 2015
    170
    58
    Next, ask if there is a SonicWALL router in the mix. If so,
    1. Go to the VoIP tab (or Firewall tab, depending on the device’s web interface)
    2. Near the top of the page, make sure Enable Consistent NAT is checked.
    3. Further down on the page, make sure Enable SIP Transformations is unchecked.
    4. Save your changes.
