One-way audio on outgoing calls
Discussion in '3CX Phone System - General' started by Yuri_M, Dec 18, 2012.
  1. Yuri_M
    Dec 18, 2012
    Edit: problem solved, wrong settings on voip provider side.
    Running 3cx phone system ver.11 sp3.
    Have problem with my voip provider - inbound calls works ok, but on outgoing calls I can hear other side, but other side getting no audio from me.
    No firewalls/NATs between my server and provider server. Whats can be wrong?
    Here is 3cx verbose log:
    Code:
    18-dec-2012 22:02:54.416	L:17.2[Line:10000>>84952314222]: Terminating targets, reason:
    18-dec-2012 22:02:54.416	Leg L:17.2[Line:10000>>84952314222] is terminated: Cause: BYE from PBX
    18-dec-2012 22:02:54.416	Terminated from <sip:84952314222@10.220.0.2:5060>;tag=48212502 to "4956462752"<sip:4956462752@10.220.0.2:5060>;tag=840cde08; reason: LocalBye
    18-dec-2012 22:02:54.416	L:17.2[Line:10000>>84952314222] Sending: OnSendReq Send Req BYE from 0.0.0.0:0 tid=711ee772d63d227b Call-ID=NzY5YTU5OTBmNjIxZjQyY2IxODA1OTM3NWZkMTYxOWQ.:
    			BYE sip:84952314222@10.220.0.2:5060;user=phone SIP/2.0
    			Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-711ee772d63d227b-1---d8754z-;rport
    			Max-Forwards: 70
    			Contact: <sip:4956462752@10.220.8.21:5060>
    			To: <sip:84952314222@10.220.0.2:5060>;tag=48212502
    			From: "4956462752"<sip:4956462752@10.220.0.2:5060>;tag=840cde08
    			Call-ID: NzY5YTU5OTBmNjIxZjQyY2IxODA1OTM3NWZkMTYxOWQ.
    			CSeq: 2 BYE
    			Content-Length: 0
    18-dec-2012 22:02:54.416	SendMsg from "4956462752"<sip:4956462752@10.220.0.2:5060>;tag=840cde08 to <sip:84952314222@10.220.0.2:5060>;tag=48212502
    18-dec-2012 22:02:54.416	[CM503008]: Call(C:17): Call is terminated
    18-dec-2012 22:02:54.416	L:17.2[Line:10000>>84952314222]: Terminating targets, reason: SIP ;cause=200 ;text="Call terminated on user request"
    18-dec-2012 22:02:54.415	Blocking refers for the Call(C:17)
    18-dec-2012 22:02:54.415	Call(C:17) is terminated
    18-dec-2012 22:02:54.414	L:17.1[Extn]: Terminating targets, reason: SIP ;cause=200 ;text="User hangup"
    18-dec-2012 22:02:54.414	Leg L:17.1[Extn] is terminated: Cause: BYE from 91.76.76.133:10899
    18-dec-2012 22:02:54.414	L:17.1[Extn] got Terminated Recv Req BYE from 91.76.76.133:10899 tid=Pjz2ZpU286CgShCmM11YDh2LfxuC6Hx4YK Call-ID=rPWbG6H9Rt-wv-BXVHHHO4861MBJQrJp:
    			BYE sip:984952314222@83.69.197.154:5060;transport=TCP SIP/2.0
    			Via: SIP/2.0/TCP 192.168.110.172:53061;rport=10899;branch=z9hG4bKPjz2ZpU286CgShCmM11YDh2LfxuC6Hx4YK;received=91.76.76.133
    			Max-Forwards: 70
    			To: <sip:984952314222@83.69.197.154:5060>;tag=5d0e1f14
    			From: <sip:66@83.69.197.154:5060>;tag=sAfqfE3zJj-cz9OvwARbj2M8xIpqIjzT
    			Call-ID: rPWbG6H9Rt-wv-BXVHHHO4861MBJQrJp
    			CSeq: 7150 BYE
    			User-Agent: 3CXPhone for Android 2.0.5
    			Content-Length: 0
    18-dec-2012 22:02:54.414	Terminated from <sip:66@83.69.197.154:5060>;tag=sAfqfE3zJj-cz9OvwARbj2M8xIpqIjzT to <sip:984952314222@83.69.197.154:5060>;tag=5d0e1f14; reason: RemoteBye
    18-dec-2012 22:02:54.414	L:17.1[Extn] Sending: OnSendResp Send 200/BYE from 0.0.0.0:0 tid=Pjz2ZpU286CgShCmM11YDh2LfxuC6Hx4YK Call-ID=rPWbG6H9Rt-wv-BXVHHHO4861MBJQrJp:
    			SIP/2.0 200 OK
    			Contact: <sip:984952314222@83.69.197.154:5060;transport=TCP>
    			CSeq: 7150 BYE
    			Content-Length: 0
    18-dec-2012 22:02:54.414	SendMsg from <sip:984952314222@83.69.197.154:5060>;tag=5d0e1f14 to <sip:66@83.69.197.154:5060>;tag=sAfqfE3zJj-cz9OvwARbj2M8xIpqIjzT
    18-dec-2012 22:02:48.968	Currently active calls - 1: [17]
    18-dec-2012 22:02:29.765	Session 2796 of leg L:17.1[Extn] is confirmed
    18-dec-2012 22:02:29.765	L:17.1[Extn] got Confirmed Recv Req ACK from 91.76.76.133:10899 tid=PjdR7jEJ.ZxV0OLMGLo42yew6ttFit8qsr Call-ID=rPWbG6H9Rt-wv-BXVHHHO4861MBJQrJp:
    			ACK sip:984952314222@83.69.197.154:5060;transport=TCP SIP/2.0
    			Via: SIP/2.0/TCP 192.168.110.172:53061;rport=10899;branch=z9hG4bKPjdR7jEJ.ZxV0OLMGLo42yew6ttFit8qsr;received=91.76.76.133
    			Max-Forwards: 70
    			CSeq: 7149 ACK
    			Content-Length: 0
    18-dec-2012 22:02:29.765	ConnCfmd from <sip:66@83.69.197.154:5060>;tag=sAfqfE3zJj-cz9OvwARbj2M8xIpqIjzT to <sip:984952314222@83.69.197.154:5060>;tag=5d0e1f14
    18-dec-2012 22:02:29.533	[CM503007]: Call(C:17): Line:10000>>84952314222 has joined, contact <sip:4956462752@10.220.0.2:5060>
    18-dec-2012 22:02:29.533	[CM503007]: Call(C:17): Extn:66 has joined, contact <sip:66@192.168.110.172:38508>
    18-dec-2012 22:02:29.533	Session 2796 of leg L:17.1[Extn] is connected
    18-dec-2012 22:02:29.533	L:17.1[Extn] got Connected.UAS Send 200/INVITE from 0.0.0.0:0 tid=Pjx8CaTHAkF3a9JDEqPtxe7sdumn.qoO.O Call-ID=rPWbG6H9Rt-wv-BXVHHHO4861MBJQrJp:
    			SIP/2.0 200 OK
    			Via: SIP/2.0/TCP 192.168.110.172:53061;rport=10899;branch=z9hG4bKPjx8CaTHAkF3a9JDEqPtxe7sdumn.qoO.O;received=91.76.76.133
    			CSeq: 7149 INVITE
    			Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
    			Content-Type: application/sdp
    			Supported: replaces
    			User-Agent: 3CXPhoneSystem 11.0.28392.820 (27565)
    			Content-Length: 272
    			v=0
    			o=3cxPS 99354673152 240451059713 IN IP4 83.69.197.154
    			s=3cxPS Audio call
    			c=IN IP4 83.69.197.154
    			t=0 0
    			m=audio 9000 RTP/AVP 3 8 0 101
    			a=rtpmap:3 GSM/8000
    			a=rtpmap:8 PCMA/8000
    			a=rtpmap:0 PCMU/8000
    			a=rtpmap:101 telephone-event/8000
    			a=fmtp:101 0-15
    			a=sendrecv
    18-dec-2012 22:02:29.533	Connected(UAS) from <sip:66@83.69.197.154:5060>;tag=sAfqfE3zJj-cz9OvwARbj2M8xIpqIjzT to <sip:984952314222@83.69.197.154:5060>;tag=5d0e1f14
    18-dec-2012 22:02:29.533	L:17.1[Extn] Sending: OnSendResp Send 200/INVITE from 0.0.0.0:0 tid=Pjx8CaTHAkF3a9JDEqPtxe7sdumn.qoO.O Call-ID=rPWbG6H9Rt-wv-BXVHHHO4861MBJQrJp:
    			SIP/2.0 200 OK
    			CSeq: 7149 INVITE
    			Supported: replaces
    			Content-Length: 272
    			v=0
    			s=3cxPS Audio call
    			t=0 0
    			a=rtpmap:3 GSM/8000
    			a=fmtp:101 0-15
    			a=sendrecv
    18-dec-2012 22:02:29.533	SendMsg from <sip:984952314222@83.69.197.154:5060>;tag=5d0e1f14 to <sip:66@83.69.197.154:5060>;tag=sAfqfE3zJj-cz9OvwARbj2M8xIpqIjzT
    18-dec-2012 22:02:29.533	~Target=VoIPline:84952314222@(Ln.10000@MT)
    18-dec-2012 22:02:29.533	L:17.1[Extn]: Terminating targets, reason: SIP ;cause=200 ;text="Call completed elsewhere"
    18-dec-2012 22:02:29.533	~Route=Dev:sip:4956462752@10.220.0.2:5060
    18-dec-2012 22:02:29.533	L:17.2[Line:10000>>84952314222] has joined to L:17.1[Extn]
    18-dec-2012 22:02:29.533	Session 2799 of leg L:17.2[Line:10000>>84952314222] is connected
    18-dec-2012 22:02:29.533	L:17.2[Line:10000>>84952314222] got Connected.UAC Recv 200/INVITE from 10.220.0.2:5060 tid=0f7ea11aa02d760a Call-ID=NzY5YTU5OTBmNjIxZjQyY2IxODA1OTM3NWZkMTYxOWQ.:
    			SIP/2.0 200 OK
    			Via: SIP/2.0/UDP 10.220.8.21:5060;branch=z9hG4bK-d8754z-0f7ea11aa02d760a-1---d8754z-;rport=5060
    			Contact: <sip:84952314222@10.220.0.2:5060;user=phone>
    			CSeq: 1 INVITE
    			Content-Length: 232
    			v=0
    			o=HuaweiSoftX3000 37839573 37839574 IN IP4 10.200.68.119
    			s=Sip Call
    			c=IN IP4 10.200.68.119
    			t=0 0
    			m=audio 30400 RTP/AVP 18 101
    			a=rtpmap:18 G729/8000
    			a=fmtp:101 0-15
    			a=fmtp:18 annexb=no
    18-dec-2012 22:02:29.533	Connected(UAC) from <sip:84952314222@10.220.0.2:5060>;tag=48212502 to "4956462752"<sip:4956462752@10.220.0.2:5060>;tag=840cde08
    18-dec-2012 22:02:29.533	Remote SDP is set for leg L:17.2[Line:10000>>84952314222]
    18-dec-2012 22:02:29.533	NAT/ALG check:L:17.2[Line:10000>>84952314222] RESPONSE 200 on 'INVITE' - some of SIP/SDP headers contain inconsistent information or modified by intermediate hop
    			   Media session IP ('c=' attribute) is not equal to the IP specified in contact header:
    			      Media session IP:10.200.68.119
    			      Contact IP:10.220.0.2
    			   Media session IP ('c=' attribute) is not equal to the SIP packet source(IP:port):
    			      Media session IP: 10.200.68.119
    			      Received from: 10.220.8.21
    18-dec-2012 22:02:29.533	Answer SDP arrived on Leg L:17.2[Line:10000>>84952314222];
    OnAnswer Recv 200/INVITE from 10.220.0.2:5060 tid=0f7ea11aa02d760a Call-ID=NzY5YTU5OTBmNjIxZjQyY2IxODA1OTM3NWZkMTYxOWQ.:
    			SIP/2.0 200 OK
    			CSeq: 1 INVITE
    			Content-Length: 232
    			v=0
    			s=Sip Call
    			t=0 0
    			a=fmtp:101 0-15
    			a=fmtp:18 annexb=no
    18-dec-2012 22:02:29.533	L:17.2[Line:10000>>84952314222] Sending: OnSendReq Send Req ACK from 0.0.0.0:0 tid=ea2907081201532e Call-ID=NzY5YTU5OTBmNjIxZjQyY2IxODA1OTM3NWZkMTYxOWQ.:
    			ACK sip:84952314222@10.220.0.2:5060;user=phone SIP/2.0
    			Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-ea2907081201532e-1---d8754z-;rport
    			Max-Forwards: 70
    			CSeq: 1 ACK
    			Content-Length: 0
    18-dec-2012 22:02:29.533	SendMsg from "4956462752"<sip:4956462752@10.220.0.2:5060>;tag=840cde08 to <sip:84952314222@10.220.0.2:5060>;tag=48212502
    18-dec-2012 22:02:29.473	Provisional response arrived for session 2799 of Leg L:17.2[Line:10000>>84952314222]
    18-dec-2012 22:02:29.473	L:17.2[Line:10000>>84952314222] got Provisional Recv 180/INVITE from 10.220.0.2:5060 tid=0f7ea11aa02d760a Call-ID=NzY5YTU5OTBmNjIxZjQyY2IxODA1OTM3NWZkMTYxOWQ.:
    			SIP/2.0 180 Ringing
    			CSeq: 1 INVITE
    			Allow: INVITE, ACK, OPTIONS, BYE, CANCEL, REGISTER, INFO, PRACK, SUBSCRIBE, NOTIFY, UPDATE, MESSAGE, REFER
    			Content-Length: 0
    18-dec-2012 22:02:29.472	Provisional(180) from <sip:84952314222@10.220.0.2:5060>;tag=48212502 to "4956462752"<sip:4956462752@10.220.0.2:5060>;tag=840cde08
    18-dec-2012 22:02:29.034	L:17.2[Line:10000>>84952314222] got EarlyMedia Recv 183/INVITE from 10.220.0.2:5060 tid=0f7ea11aa02d760a Call-ID=NzY5YTU5OTBmNjIxZjQyY2IxODA1OTM3NWZkMTYxOWQ.:
    			SIP/2.0 183 Session Progress
    			CSeq: 1 INVITE
    			Content-Length: 232
    			v=0
    			o=HuaweiSoftX3000 37839573 37839573 IN IP4 10.200.68.119
    			s=Sip Call
    			t=0 0
    			a=fmtp:101 0-15
    			a=fmtp:18 annexb=no
    18-dec-2012 22:02:29.034	EarlyMedia from <sip:84952314222@10.220.0.2:5060>;tag=48212502 to "4956462752"<sip:4956462752@10.220.0.2:5060>;tag=840cde08
    18-dec-2012 22:02:29.034	L:17.1[Extn] Sending: OnSendResp Send 183/INVITE from 0.0.0.0:0 tid=Pjx8CaTHAkF3a9JDEqPtxe7sdumn.qoO.O Call-ID=rPWbG6H9Rt-wv-BXVHHHO4861MBJQrJp:
    			CSeq: 7149 INVITE
    			Content-Length: 272
    			v=0
    			s=3cxPS Audio call
    			t=0 0
    			a=rtpmap:3 GSM/8000
    			a=fmtp:101 0-15
    			a=sendrecv
    18-dec-2012 22:02:29.034	SendMsg from <sip:984952314222@83.69.197.154:5060>;tag=5d0e1f14 to <sip:66@83.69.197.154:5060>;tag=sAfqfE3zJj-cz9OvwARbj2M8xIpqIjzT
    18-dec-2012 22:02:29.033	Remote SDP is set for leg L:17.2[Line:10000>>84952314222]
    18-dec-2012 22:02:29.033	Provisional response arrived for session 2799 of Leg L:17.2[Line:10000>>84952314222]
    18-dec-2012 22:02:29.033	L:17.2[Line:10000>>84952314222] got Provisional Recv 183/INVITE from 10.220.0.2:5060 tid=0f7ea11aa02d760a Call-ID=NzY5YTU5OTBmNjIxZjQyY2IxODA1OTM3NWZkMTYxOWQ.:
    			CSeq: 1 INVITE
    			Content-Length: 232
    			v=0
    			s=Sip Call
    			t=0 0
    			a=fmtp:101 0-15
    			a=fmtp:18 annexb=no
    18-dec-2012 22:02:29.033	Provisional(183) from <sip:84952314222@10.220.0.2:5060>;tag=48212502 to "4956462752"<sip:4956462752@10.220.0.2:5060>;tag=840cde08
    18-dec-2012 22:02:29.033	[CM505003]: Provider:[MT] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Huawei SoftX3000 V300R006] PBX contact: [sip:4956462752@10.220.8.21:5060]
    18-dec-2012 22:02:29.033	[CM503002]: Call(C:17): Alerting Line:10000>>84952314222 by contact <sip:4956462752@10.220.0.2:5060>
    18-dec-2012 22:02:29.033	UacSession 2799 has formed leg L:17.2[Line:10000>>84952314222]
    18-dec-2012 22:02:29.033	Answer from <sip:84952314222@10.220.0.2:5060>;tag=48212502 to "4956462752"<sip:4956462752@10.220.0.2:5060>;tag=840cde08
    18-dec-2012 22:02:28.267	[CM503025]: Call(C:17): Calling T:Line:10000>>84952314222@[Dev:sip:4956462752@10.220.0.2:5060] for L:17.1[Extn]
    18-dec-2012 22:02:28.267	Route to L:17.2[Line:10000>>84952314222] sends Invite-OUT Send Req INVITE from 0.0.0.0:0 tid=a1534e45b751b605 Call-ID=NzY5YTU5OTBmNjIxZjQyY2IxODA1OTM3NWZkMTYxOWQ.:
    			INVITE sip:84952314222@10.220.0.2:5060 SIP/2.0
    			Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-a1534e45b751b605-1---d8754z-;rport
    			Max-Forwards: 70
    			CSeq: 1 INVITE
    			Supported: replaces
    			Content-Length: 299
    			Remote-Party-ID: "4956462752"<sip:4956462752@10.220.0.2:5060>;party=calling
    			v=0
    			o=3cxPS 110528299008 135023034369 IN IP4 10.220.8.21
    			s=3cxPS Audio call
    			c=IN IP4 10.220.8.21
    			t=0 0
    			m=audio 7064 RTP/AVP 18 0 8 3 101
    			a=fmtp:18 annexb=no
    			a=rtpmap:3 GSM/8000
    			a=sendrecv
    18-dec-2012 22:02:28.261	Outbound URI is used: sip:10.220.0.2:5060
    18-dec-2012 22:02:28.261	SLA is globally disabled
    18-dec-2012 22:02:28.261	Added leg L:17.2[Line:10000>>84952314222]
    18-dec-2012 22:02:28.225	[Flow] Call(C:17): making call from L:17.1[Extn] to T:Line:10000>>84952314222@[Dev:sip:4956462752@10.220.0.2:5060]
  2. mixig
    mixig Active Member
    Dec 13, 2011
    519
    11
    In 3cx management console: Settings->Firewall Checker
    You will see with that is your firweall/NAT configuration ok. Did you add static nat on your router/firewall for udp ports 9000-9049 from outside to forward to local ip of 3cx?
    But fisrt run firewall checker
  3. Yuri_M
    Dec 18, 2012
    as I told before, there is no nat/firewall on way. My server with 3cx connected to provider's voip server directly (10.x.x.x network).
  4. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Думаю, что проблемы тут две...
    (I think that here are two problems)
    Первая:
    (First one:)
    Неизвестное устройство, которое неизвестно как подключено...
    (The unknown device and nobody knows how it is connected/configured)
    Вторая:
    (Second one)
    Провайдер, который, на мой взгляд, "страннее некуда"...
    (The VoIP provider which is, in my opinion, "really strange")
    Предоставьте, пожалуйста, "топологию" и подробную информацию об участниках инцидента
    (Could you please provide information about network topology and devices which are participating in this "incident")
    Спасибо
    (Thanks)
  5. Yuri_M
    Dec 18, 2012
    83.69.197.154 - ip of another network card on my server (there are 3 of em - 83.69.197.154 - internet, 192.168.99.2 - internal network, 10.220.8.21 - network directly connected to voip provider)
    91.76.76.133 - its my home ip, from where I currently testing (using 3cx phone client). From internal network all results been same.
    Provider - mastertel.ru.
    With some strange settings, yes. Incoming calls works ok, only problem with outbound. I receive rtp stream from provider on outgoin call, but my 3cx not sending rtp to address given by provider on INVITE (these 10.200.68.119)
