One way audio with Andrews and Arnold Voip
Discussion in '3CX Phone System - General' started by mrh, Dec 24, 2017.
  1. mrh
    mrh
    Jun 12, 2017
    After a lot of testing, we have determined that the problem is isolated to our AAISP trunks. Voipfone and voip.co.uk trunks work ok.
    If we receive a call on either of our A&A trunks all is ok - audio works in both directions.
    If we make an outgoing call over the trunk, we can here the caller, but cannot here us. We still hear a slight echo of our own part of the conversation.
    As I said, it is only a problem on outgoing trunks for A&A.
    Running 3CX 15.5.0 with a pfsense firewall. The firewall checker completes successfully.
    Is anyone else an Andrews and Arnold customer who could offer some assistance?
    Many thanks
    Matthew
  2. Archie Frederic
    Jan 31, 2017
    69
    Disable sip ALG on the firewall. or duplicate a wireshark capture containing the packets that contains the issue to trace the problem.
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,392
    279
    Hello @mrh
    I would recommend you stick with supported providers which are tested for compatibility with 3CX to avoid these issues in the future. You find a list with of the supported providers here.
