One way audio with Iphone 3G connection
Discussion in 'iOS' started by zhangjx99, Nov 20, 2010.
  1. zhangjx99
    May 26, 2010
    51
    Hi there,
    3CX Iphone client is working fine with Wifi connection, but with 3G connection, one way audio issue.
    Since it work fine with Wifi connection, I suspect 3G vendor (in Singapore) has blocked SIP port 5060, is there any alternative?
    I don't want to change server SIP port 5060 just because of the Iphone extension issue. is there anyway to setup both 5060 and 5061 port at the same one 3CX server?
    Thanks.
    JX
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    If your sip vendor is at fault altough since the call is connected it might not be that then you can create a VPN from your phone to your PBX. THis should conquer the problem.
  3. Sarah Hastings
    Nov 24, 2010
    15
    You cannot place both SIP port servers on one 3CXPhone system. But you could try the other way around by utilizing some kind of proxy SIP address or changing software.
  4. gmcfad
    Feb 14, 2010
    I'm having the same issue - but with both 3CX for Iphone and Acrobits. Both have one way audio. (outbound from Iphone)
    But FRING works fine. And when I make the test calls to an extension here on my home PBX if almost sounds like the outgoing audio in looped back from my internal extensions. But again, only with 3CX for Iphone and Acrobits. Very strange.
  5. StefanW
    Jun 2, 2009
    1,210
    85
    3CXPhone and Acrobits are both direkt SIp Clients, Fring is an Proxy Service with a "Man in the Middel" the codec is porpierty so not directly sip and not been catched by the provider, to get arround this issue use VPN from the Iphone or we wait if we can make a tunnel service for the phone as we have it on windows.
  6. tworhythms
    Sep 15, 2010
    19
    I had this problem as well. For those who are experiencing one-way audio over 3G you can try asking your provider to enable VPN access (might be a small monthly charge). Then you will need to modify the APN settings on the iPhone (there are guides on the internet on how to do this). The big issue is that most internet.com APNs and others are behind NAT. When your provider enables VPN access on your account it should provide you with a public IP on your iPhone (at least it does with Rogers in Canada). I can now make 2-Way audio calls over 3G with my iPhone!!
  7. Sarah Hastings
    Nov 24, 2010
    15
    Is there any other way around the provider thing....Something like SIP settings or what?
