One Way Audio With OpenVPN
Discussion in '3CX Phone System - General' started by qlxltd, Dec 3, 2008.
  1. qlxltd
    Nov 3, 2008
    25
    I've set up an OpenVPN between 2 sites. I have 3cx installed at site one using bridged network and I have a PC at site two with OpenVPN also using network bridge connecting to site one.
    All extensions at site 2 register with no problem and can make and receive calls. The only issue is if either site try to transfers a call. The result is one way audio (site two can hear site one but site one can not hear site two)
    Any ideas?
  2. galal202
    galal202 New Member
    Jun 23, 2008
    235
    Hello and welcome,
    did set dns correct?
    what is your voip client?
  3. worksighted
    worksighted New Member
    Aug 19, 2008
    204
    Are you using different subnets at each site (e.g., 1.x and 2.x) but using bridged ethernet for the OpenVPN? Or are they on the same subnet (e.g., both are 1.x) ?
    Mike
  4. qlxltd
    Nov 3, 2008
    25
    On site 1 im using 10.14.3.x and site 2 10.14.4.x with subnet of 255.0.0.0
    The DNS at site one is a Windows Server 2003 running DNS on 10.14.3.15 with second DNS of 10.14.3.1 (The Router)
    Site 2 just uses 10.14.4.1 (The Router)
    Just did an experiment. When I call site 2, they can transfer my call to another extension without a problem. Bothe sies are using an identical PC and setup. The only difference is site 1 has the Windows Server as the primary DNS.
    Perhaps a DNS problem?
  5. qlxltd
    Nov 3, 2008
    25
    OK Just caused an outage here!
    In the 3cx box ip settings I had
    IP 10.14.3.8
    Subnet 255.0.0.0
    Default Gateway 10.14.3.1
    Preferred DNS 10.14.3.15
    Alternative DNS 10.14.3.1
    I changed the Preferred to 10.14.3.1 and removed the Alternative DNS. I thought that the 3cx box would ask the router to resove DNS and forward them out to wan but after a short period of time all of the lines became unregistered and in the 3cx log it showed that it couldnt connect to the stun server.
    I changed it all back and rebooted everything and all working as before.
    In the router setup page I have
    Ethernet TCP / IP and DHCP Setup
    LAN IP Network Configuration
    For NAT Usage
    1st IP Address 10.14.3.1
    1st Subnet Mask 255.0.0.0
    For IP Routing Usage Disabled
    2nd IP Address
    2nd Subnet Mask
    DHCP Server Configuration
    Start IP Address 10.14.3.100
    IP Pool Counts 100
    Gateway IP Address 10.14.3.1
    Primary IP Address 10.14.3.15
    Secondary IP Address 10.14.3.1
  6. worksighted
    Aug 19, 2008
    204
    As an experiment....choose 1 extension at site 1 and 1 extension at site 2. Set both of these extensions to "PBX delivers audio". Does your call transfering work then?
    Mike
  7. qlxltd
    Nov 3, 2008
    25
    Hi Mike,
    How's the Baby??
    I've tried the PBX Delivers Audio option in all combinations and it still does not work. I can always get call transfers to work at site 2 where no windows DNS server is running (just using the default gateway as DNS) So I must be an issue with my DNS settings. I'm using various DNS entries for local website content as primary DNS 10.14.3.15 and secondry as 10.14.3.1 (The routers default gateway) This way if I type in an address that my own DNS server can not find then it's forwarded to the router and outside (as far as I know)
  8. worksighted
    Aug 19, 2008
    204
    Hi. He's doing well. but mom and dad are tired! :)
    Can you post the 3CX logs for me that you capture during a test?
    Mike
  9. wzaatar
    Aug 1, 2007
    90
    I believe your secondary location has a different exit point for the internet?
    Can you try the following: ** Works for 6.1, 7.0 seems to have issues **
    - In 3cxphonesystem.ini, under the [Network] Section, add: LocalSubnets=0.0.0.0/0
    - disable all audio relay from the PBX everywhere.
    - Make sure you have no stun configured on your ATA devices, the only STUN setting should be in the 3cx config only.
    W.
  10. qlxltd
    Nov 3, 2008
    25
    Here is the log, extension 55 at the remote location calls extension 10 (local) and then transfers to extension 11 (local)
    After transfer 55 can hear 11 but 11 hears nothing at all
    Code:
    17:32:01.812 Call::Terminate [CM503008]: Call(63): Call is terminated
    17:31:54.687 MediaServerReporting::SetRemoteParty [MS210001] C:63.1:Answer received. RTP connection: 10.14.4.21:52658(52659)
    17:31:54.687 CallLeg::setRemoteSdp Remote SDP is set for legC:63.1
    17:31:54.312 MediaServerReporting::SetRemoteParty [MS210002] C:63.1:Offer provided. Connection(transcoding mode): 10.14.3.8:7180(7181)
    17:31:54.312 CallCtrl::onLegConnected [CM503007]: Call(63): Device joined: sip:11@10.14.3.41:2048;line=t4pt0b29
    17:31:54.312 MediaServerReporting::SetRemoteParty [MS210001] C:63.3:Answer received. RTP connection: 10.14.3.41:64712(64713)
    17:31:54.312 CallLeg::setRemoteSdp Remote SDP is set for legC:63.3
    17:31:51.359 Extension::printEndpointInfo [CM505001]: Ext.11: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom300/7.1.30] Transport: [sip:10.14.3.8:5060]
    17:31:51.359 CallCtrl::onAnsweredCall [CM503002]: Call(63): Alerting sip:11@10.14.3.41:2048;line=t4pt0b29
    17:31:50.343 MediaServerReporting::SetRemoteParty [MS210002] C:63.3:Offer provided. Connection(transcoding mode): 10.14.3.8:7188(7189)
    17:31:50.343 CallCtrl::onSelectRouteReq [CM503004]: Call(63): Calling: Ext:Ext.11@[Dev:sip:11@10.14.3.41:2048;line=t4pt0b29]
    17:31:50.343 CallCtrl::onSelectRouteReq [CM503010]: Making route(s) to [sip:11@10.14.3.8:5060;user=phone]
    17:31:50.343 CallLeg::onRefer Refer: from=[sip:10@10.14.3.8:5060];tag=36u7gbpxfa; to="21"[sip:55@10.14.3.8:5060];tag=830ae231; RefTo=[sip:11@10.14.3.8:5060;user=phone]
    17:31:50.328 Call::Terminate [CM503008]: Call(64): Call is terminated
    17:31:49.328 Extension::printEndpointInfo [CM505001]: Ext.11: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom300/7.1.30] Transport: [sip:10.14.3.8:5060]
    17:31:49.328 CallCtrl::onAnsweredCall [CM503002]: Call(64): Alerting sip:11@10.14.3.41:2048;line=t4pt0b29
    17:31:48.765 MediaServerReporting::SetRemoteParty [MS210002] C:64.2:Offer provided. Connection(transcoding mode): 10.14.3.8:7186(7187)
    17:31:48.765 CallCtrl::onSelectRouteReq [CM503004]: Call(64): Calling: Ext:Ext.11@[Dev:sip:11@10.14.3.41:2048;line=t4pt0b29]
    17:31:48.765 CallCtrl::onSelectRouteReq [CM503010]: Making route(s) to [sip:11@10.14.3.8:5060;user=phone]
    17:31:48.765 MediaServerReporting::SetRemoteParty [MS210000] C:64.1:Offer received. RTP connection: 10.14.3.40:57284(57285)
    17:31:48.765 CallLeg::setRemoteSdp Remote SDP is set for legC:64.1
    17:31:48.765 Extension::printEndpointInfo [CM505001]: Ext.10: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom300/7.3.7] Transport: [sip:10.14.3.8:5060]
    17:31:48.765 CallCtrl::onIncomingCall [CM503001]: Call(64): Incoming call from Ext.10 to [sip:11@10.14.3.8:5060;user=phone]
    17:31:48.750 CallLeg::onNewCall [CM500002]: Info on incoming INVITE:
    INVITE sip:11@10.14.3.8:5060;user=phone SIP/2.0
    Via: SIP/2.0/UDP 10.14.3.40:2048;branch=z9hG4bK-j3krt91hvi2v;rport=2048
    Max-Forwards: 70
    Contact: [sip:10@10.14.3.40:2048;line=h155eph4];reg-id=1
    To: [sip:11@10.14.3.8:5060;user=phone]
    From: "Steve Bouffe"[sip:10@10.14.3.8:5060];tag=mpp8gn01di
    Call-ID: 3c45325fb106-zjp97xvjsejx
    CSeq: 2 INVITE
    Session-Expires: 3600;refresher=uas
    Min-SE: 90
    Accept: application/sdp
    Allow: INVITE, ACK, CANCEL, BYE, REFER, OPTIONS, NOTIFY, SUBSCRIBE, PRACK, MESSAGE, INFO
    Proxy-Authorization: Digest username="10",realm="3CXPhoneSystem",nonce="12874095108:32cdcaa8b7f860a68b1391183c4bb7e2",uri="sip:11@10.14.3.8:5060;user=phone",response="3bb6f5f28c0c066fdbeb8c849cc603ca",algorithm=MD5
    Supported: timer, 100rel, replaces, from-change
    User-Agent: snom300/7.3.7
    Allow-Events: talk, hold, refer, call-info
    Content-Length: 0
    P-Key-Flags: keys="3"
    17:31:47.000 MediaServerReporting::SetRemoteParty [MS210003] C:63.2:Answer provided. Connection(transcoding mode):10.14.3.8:7182(7183)
    17:31:47.000 MediaServerReporting::SetRemoteParty [MS210001] C:63.1:Answer received. RTP connection: 10.14.4.21:52658(52659)
    17:31:47.000 CallLeg::setRemoteSdp Remote SDP is set for legC:63.1
    17:31:46.687 MediaServerReporting::SetRemoteParty [MS210002] C:63.1:Offer provided. Connection(transcoding mode): 10.14.3.8:7180(7181)
    17:31:46.687 MediaServerReporting::SetRemoteParty [MS210000] C:63.2:Offer received. RTP connection: 10.14.3.40:56478(56479)
    17:31:46.687 CallLeg::setRemoteSdp Remote SDP is set for legC:63.2
    17:31:41.140 CallLeg::onConfirmed Session 1618 of leg C:63.1 is confirmed
    17:31:40.890 CallCtrl::onLegConnected [CM503007]: Call(63): Device joined: sip:10@10.14.3.40:2048;line=h155eph4
    17:31:40.890 CallCtrl::onLegConnected [CM503007]: Call(63): Device joined: sip:55@10.14.4.21:2048;line=ehi4l23a
    17:31:40.890 MediaServerReporting::SetRemoteParty [MS210003] C:63.1:Answer provided. Connection(transcoding mode):10.14.3.8:7180(7181)
    17:31:40.890 Call::RecordCall [CM503020]: Call(63): Call recording is started, audio file: ..\Data\Recordings\[21]_55-10_20081218173140(63).wav
    17:31:40.828 MediaServerReporting::SetRemoteParty [MS210001] C:63.2:Answer received. RTP connection: 10.14.3.40:56478(56479)
    17:31:40.828 CallLeg::setRemoteSdp Remote SDP is set for legC:63.2
    17:31:38.781 Extension::printEndpointInfo [CM505001]: Ext.10: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom300/7.3.7] Transport: [sip:10.14.3.8:5060]
    17:31:38.781 CallCtrl::onAnsweredCall [CM503002]: Call(63): Alerting sip:10@10.14.3.40:2048;line=h155eph4
    17:31:38.390 MediaServerReporting::SetRemoteParty [MS210002] C:63.2:Offer provided. Connection(transcoding mode): 10.14.3.8:7182(7183)
    17:31:38.375 MediaServerReporting::SetRemoteParty [MS210000] C:63.1:Offer received. RTP connection: 10.14.4.21:52658(52659)
    17:31:38.375 CallCtrl::onSelectRouteReq [CM503004]: Call(63): Calling: Ext:Ext.10@[Dev:sip:10@10.14.3.40:2048;line=h155eph4]
    17:31:38.375 CallCtrl::onSelectRouteReq [CM503010]: Making route(s) to [sip:10@10.14.3.8:5060;user=phone]
    17:31:38.375 CallLeg::setRemoteSdp Remote SDP is set for legC:63.1
    17:31:38.375 Extension::printEndpointInfo [CM505001]: Ext.55: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom300/7.1.30] Transport: [sip:10.14.3.8:5060]
    17:31:38.375 CallCtrl::onIncomingCall [CM503001]: Call(63): Incoming call from Ext.55 to [sip:10@10.14.3.8:5060;user=phone]
    17:31:38.375 CallLeg::onNewCall [CM500002]: Info on incoming INVITE:
    INVITE sip:10@10.14.3.8:5060;user=phone SIP/2.0
    Via: SIP/2.0/UDP 10.14.4.21:2048;branch=z9hG4bK-24ea0hby0k2w;rport=2048
    Max-Forwards: 70
    Contact: [sip:55@10.14.4.21:2048;line=ehi4l23a];flow-id=1
    To: [sip:10@10.14.3.8:5060;user=phone]
    From: "Thurrock DJ"[sip:55@10.14.3.8:5060];tag=jl0jxr3t4j
    Call-ID: 3c325f3b45f8-p4mhhcpj2t3v
    CSeq: 2 INVITE
    Min-SE: 90
    Proxy-Authorization: Digest username="55",realm="3CXPhoneSystem",nonce="12874095096:285a261a1e53b2b329ce09bcf29025f5",uri="sip:10@10.14.3.8:5060;user=phone",response="d658a9219a855a7a481b43af917c5417",algorithm=MD5
    Supported: timer, 100rel, replaces, callerid
    User-Agent: snom300/7.1.30
    Content-Length: 0
  11. kevin
    kevin Member
    Nov 23, 2006
    316
    Hi there
    To assist with troubleshooting, please try to set all involved extensions to "PBX Delivers Audio" and advise whether it helps.
    Part of the source of the problem must be related to the fact that some extensions are on 10.14.3.x and some are on 10.14.4.x
    If you can reconfigure the OpenVPN link in such a way that all the relevant extensions are on the same subnet, that should also help to resolve the issue.
    Regards
    Kevin
  12. qlxltd
    Nov 3, 2008
    25
    Site one is on 10.14.3.xx and site two on 10.14.4.xx with subnet of 255.0.0.0
    When I call site 2 from site one then they can transfer my call without any issues, its only when site 2 calls site one and then makes the transfer with one way audio so I dont think that it's a subnet issue. I can only think that it's something to do whith our internal DNS server causing the problem at site 1.
    I have a wireshark capture, is it safe to post these files here? Does the capture contain usernames/passwords etc?
  13. worksighted
    Aug 19, 2008
    204
    Based on your subnets and masks you have indicated, everything shoudl be on one contiguous subnet so, in theory, that's fine.
    Can you disable call recording on all of these extensions and test again and post log?
    Thanks.
    Mike
  14. qlxltd
    Nov 3, 2008
    25
    Hi Mike,
    Disabled the call recording and extensions 10,11 and 55. Tested again and still one way audio. Here is the 3cx log.
    Code:
    10:43:42.898 Call::Terminate [CM503008]: Call(157): Call is terminated
    10:43:38.508 MediaServerReporting::SetRemoteParty [MS210001] C:157.1:Answer received. RTP connection: 10.14.4.21:52896(52897)
    10:43:38.508 CallLeg::setRemoteSdp Remote SDP is set for legC:157.1
    10:43:38.195 CallCtrl::onLegConnected [CM503007]: Call(157): Device joined: sip:11@10.14.3.41:2048;line=t4pt0b29
    10:43:38.195 MediaServerReporting::SetRemoteParty [MS210002] C:157.1:Offer provided. Connection(transcoding mode): 10.14.3.8:7120(7121)
    10:43:38.195 MediaServerReporting::SetRemoteParty [MS210001] C:157.3:Answer received. RTP connection: 10.14.3.41:65458(65459)
    10:43:38.195 CallLeg::setRemoteSdp Remote SDP is set for legC:157.3
    10:43:35.679 Extension::printEndpointInfo [CM505001]: Ext.11: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom300/7.1.30] Transport: [sip:10.14.3.8:5060]
    10:43:35.679 CallCtrl::onAnsweredCall [CM503002]: Call(157): Alerting sip:11@10.14.3.41:2048;line=t4pt0b29
    10:43:34.554 MediaServerReporting::SetRemoteParty [MS210002] C:157.3:Offer provided. Connection(transcoding mode): 10.14.3.8:7128(7129)
    10:43:34.554 CallCtrl::onSelectRouteReq [CM503004]: Call(157): Calling: Ext:Ext.11@[Dev:sip:11@10.14.3.41:2048;line=t4pt0b29]
    10:43:34.554 CallCtrl::onSelectRouteReq [CM503010]: Making route(s) to [sip:11@10.14.3.8:5060;user=phone]
    10:43:34.554 CallLeg::onRefer Refer: from=[sip:10@10.14.3.8:5060];tag=n2xvwz1f62; to="21"[sip:55@10.14.3.8:5060];tag=72399232; RefTo=[sip:11@10.14.3.8:5060;user=phone]
    10:43:34.554 Call::Terminate [CM503008]: Call(158): Call is terminated
    10:43:33.367 Extension::printEndpointInfo [CM505001]: Ext.11: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom300/7.1.30] Transport: [sip:10.14.3.8:5060]
    10:43:33.367 CallCtrl::onAnsweredCall [CM503002]: Call(158): Alerting sip:11@10.14.3.41:2048;line=t4pt0b29
    10:43:32.789 MediaServerReporting::SetRemoteParty [MS210002] C:158.2:Offer provided. Connection(transcoding mode): 10.14.3.8:7126(7127)
    10:43:32.789 MediaServerReporting::SetRemoteParty [MS210000] C:158.1:Offer received. RTP connection: 10.14.3.40:59348(59349)
    10:43:32.789 CallCtrl::onSelectRouteReq [CM503004]: Call(158): Calling: Ext:Ext.11@[Dev:sip:11@10.14.3.41:2048;line=t4pt0b29]
    10:43:32.789 CallCtrl::onSelectRouteReq [CM503010]: Making route(s) to [sip:11@10.14.3.8:5060;user=phone]
    10:43:32.773 CallLeg::setRemoteSdp Remote SDP is set for legC:158.1
    10:43:32.773 Extension::printEndpointInfo [CM505001]: Ext.10: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom300/7.3.7] Transport: [sip:10.14.3.8:5060]
    10:43:32.773 CallCtrl::onIncomingCall [CM503001]: Call(158): Incoming call from Ext.10 to [sip:11@10.14.3.8:5060;user=phone]
    10:43:32.773 CallLeg::onNewCall [CM500002]: Info on incoming INVITE:
    Via: SIP/2.0/UDP 10.14.3.40:2048;branch=z9hG4bK-eclhoyl9ebq1;rport=2048
    Max-Forwards: 70
    Contact: [sip:10@10.14.3.40:2048;line=pczpmvxq];reg-id=1
    From: "Steve Bouffe"[sip:10@10.14.3.8:5060];tag=zi1biut1ij
    Call-ID: 3c2d0ba2ae30-5l0vph2uc7j1
    CSeq: 2 INVITE
    Min-SE: 90
    Proxy-Authorization: Digest username="10",realm="3CXPhoneSystem",nonce="12875021012:7a31e8987cc66d1fda8802093c90b68e",uri="sip:11@10.14.3.8:5060;user=phone",response="eb4d86021416c260bdb85d307bb80245",algorithm=MD5
    Content-Length: 0
    10:43:31.539 MediaServerReporting::SetRemoteParty [MS210003] C:157.2:Answer provided. Connection(transcoding mode):10.14.3.8:7122(7123)
    10:43:31.539 MediaServerReporting::SetRemoteParty [MS210001] C:157.1:Answer received. RTP connection: 10.14.4.21:52896(52897)
    10:43:31.539 CallLeg::setRemoteSdp Remote SDP is set for legC:157.1
    10:43:31.242 MediaServerReporting::SetRemoteParty [MS210002] C:157.1:Offer provided. Connection(transcoding mode): 10.14.3.8:7120(7121)
    10:43:31.242 MediaServerReporting::SetRemoteParty [MS210000] C:157.2:Offer received. RTP connection: 10.14.3.40:53776(53777)
    10:43:31.242 CallLeg::setRemoteSdp Remote SDP is set for legC:157.2
    10:43:17.679 CallLeg::onConfirmed Session 24569 of leg C:157.1 is confirmed
    10:43:17.476 CallCtrl::onLegConnected [CM503007]: Call(157): Device joined: sip:10@10.14.3.40:2048;line=pczpmvxq
    10:43:17.476 CallCtrl::onLegConnected [CM503007]: Call(157): Device joined: sip:55@10.14.4.21:2048;line=ehi4l23a
    10:43:17.476 MediaServerReporting::SetRemoteParty [MS210003] C:157.1:Answer provided. Connection(transcoding mode):10.14.3.8:7120(7121)
    10:43:17.476 MediaServerReporting::SetRemoteParty [MS210001] C:157.2:Answer received. RTP connection: 10.14.3.40:53776(53777)
    10:43:17.476 CallLeg::setRemoteSdp Remote SDP is set for legC:157.2
    10:43:15.726 Extension::printEndpointInfo [CM505001]: Ext.10: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom300/7.3.7] Transport: [sip:10.14.3.8:5060]
    10:43:15.726 CallCtrl::onAnsweredCall [CM503002]: Call(157): Alerting sip:10@10.14.3.40:2048;line=pczpmvxq
    10:43:15.554 MediaServerReporting::SetRemoteParty [MS210000] C:157.1:Offer received. RTP connection: 10.14.4.21:52896(52897)
    10:43:15.554 CallLeg::setRemoteSdp Remote SDP is set for legC:157.1
    10:43:15.554 MediaServerReporting::SetRemoteParty [MS210002] C:157.2:Offer provided. Connection(transcoding mode): 10.14.3.8:7122(7123)
    10:43:15.539 CallCtrl::onSelectRouteReq [CM503004]: Call(157): Calling: Ext:Ext.10@[Dev:sip:10@10.14.3.40:2048;line=pczpmvxq]
    10:43:15.539 CallCtrl::onSelectRouteReq [CM503010]: Making route(s) to [sip:10@10.14.3.8:5060;user=phone]
    10:43:15.539 Extension::printEndpointInfo [CM505001]: Ext.55: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom300/7.1.30] Transport: [sip:10.14.3.8:5060]
    10:43:15.539 CallCtrl::onIncomingCall [CM503001]: Call(157): Incoming call from Ext.55 to [sip:10@10.14.3.8:5060;user=phone]
    10:43:15.539 CallLeg::onNewCall [CM500002]: Info on incoming INVITE:
    Via: SIP/2.0/UDP 10.14.4.21:2048;branch=z9hG4bK-3amo2dtghr2v;rport=2048
    Max-Forwards: 70
    From: "Thurrock DJ"[sip:55@10.14.3.8:5060];tag=nmyajd4au7
    Call-ID: 3c407ff4ac83-rjrgga522g3i
    CSeq: 2 INVITE
    Min-SE: 90
    Proxy-Authorization: Digest username="55",realm="3CXPhoneSystem",nonce="12875020995:721d4380f66c2eac07817d8be385a256",uri="sip:10@10.14.3.8:5060;user=phone",response="d261c5c63fd45e65202c1e50f7de41ea",algorithm=MD5
    Content-Length: 0
    10:43:05.258 Call::Terminate [CM503008]: Call(156): Call is terminated
    10:42:44.648 CallLeg::onConfirmed Session 24559 of leg C:156.1 is confirmed
    10:42:44.523 CallCtrl::onLegConnected [CM503007]: Call(156): Device joined: sip:2668298@sipgate.co.uk:5060
    10:42:44.523 CallCtrl::onLegConnected [CM503007]: Call(156): Device joined: sip:10@10.14.3.40:2048;line=pczpmvxq
    10:42:44.523 MediaServerReporting::SetRemoteParty [MS210003] C:156.1:Answer provided. Connection(transcoding mode):10.14.3.8:7118(7119)
    10:42:44.523 MediaServerReporting::SetRemoteParty [MS210001] C:156.2:Answer received. RTP connection: 217.10.77.22:35410(35411)
    10:42:44.523 CallLeg::setRemoteSdp Remote SDP is set for legC:156.2
    10:42:38.711 Line::printEndpointInfo [CM505003]: Provider:[Sip Gate] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] Transport: [sip:10.14.3.8:5060]
    10:42:38.711 CallCtrl::onAnsweredCall [CM503002]: Call(156): Alerting sip:2668298@sipgate.co.uk:5060
    10:42:37.023 MediaServerReporting::SetRemoteParty [MS210002] C:156.2:Offer provided. Connection(transcoding mode): 81.130.211.188:9004(9005)
    10:42:36.773 CallCtrl::onSelectRouteReq [CM503004]: Call(156): Calling: VoIPline:01375888234@(Ln.10002@Sip Gate)@[Dev:sip:2668298@sipgate.co.uk:5060]
    10:42:36.758 CallCtrl::onSelectRouteReq [CM503010]: Making route(s) to [sip:901375888234@10.14.3.8:5060;user=phone]
    10:42:36.758 MediaServerReporting::SetRemoteParty [MS210000] C:156.1:Offer received. RTP connection: 10.14.3.40:56378(56379)
    10:42:36.758 CallLeg::setRemoteSdp Remote SDP is set for legC:156.1
    10:42:36.758 Extension::printEndpointInfo [CM505001]: Ext.10: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom300/7.3.7] Transport: [sip:10.14.3.8:5060]
    10:42:36.758 CallCtrl::onIncomingCall [CM503001]: Call(156): Incoming call from Ext.10 to [sip:901375888234@10.14.3.8:5060;user=phone]
    10:42:36.758 CallLeg::onNewCall [CM500002]: Info on incoming INVITE:
    INVITE sip:901375888234@10.14.3.8:5060;user=phone SIP/2.0
    Via: SIP/2.0/UDP 10.14.3.40:2048;branch=z9hG4bK-qtk56rid1ylk;rport=2048
    Max-Forwards: 70
    To: [sip:901375888234@10.14.3.8:5060;user=phone]
    From: "Steve Bouffe"[sip:10@10.14.3.8:5060];tag=e4kzev8u22
    Call-ID: 3c2d0b6804b3-38rvo7o7ezuj
    CSeq: 2 INVITE
    Min-SE: 90
    Proxy-Authorization: Digest username="10",realm="3CXPhoneSystem",nonce="12875020956:25e347303eb603c881536616aa00e608",uri="sip:901375888234@10.14.3.8:5060;user=phone",response="5985a55d9808f9b571e56af47a5c8eb6",algorithm=MD5
    Content-Length: 0
    10:42:18.633 ExtnMgr::updateFromDB Extension 55 is updated
    10:42:05.336 ExtnMgr::updateFromDB Extension 11 is updated
    10:41:56.289 ExtnMgr::updateFromDB Extension 10 is updated
    10:41:52.914 Call::Terminate [CM503008]: Call(155): Call is terminated
    10:35:49.179 CallLeg::onConfirmed Session 24519 of leg C:155.1 is confirmed
    10:35:49.070 CallCtrl::onLegConnected [CM503007]: Call(155): Device joined: sip:01702520020@sip.voip-unlimited.net:5060
    10:35:49.070 CallCtrl::onLegConnected [CM503007]: Call(155): Device joined: sip:13@10.14.3.43:2048;line=gzqzgbyc
    10:35:49.070 Call::RecordCall [CM503020]: Call(155): Call recording is started, audio file: ..\Data\Recordings\[13 Till]_13-07770381098_20081229103549(155).wav
    10:35:49.054 MediaServerReporting::SetRemoteParty [MS210001] C:155.2:Answer received. RTP connection: 91.151.2.133:62264(62265)
    10:35:49.054 CallLeg::setRemoteSdp Remote SDP is set for legC:155.2
    10:35:41.226 MediaServerReporting::SetRemoteParty [MS210003] C:155.1:Answer provided. Connection(transcoding mode):10.14.3.8:7116(7117)
    10:35:41.226 MediaServerReporting::SetRemoteParty [MS210001] C:155.2:Answer received. RTP connection: 91.151.2.133:62264(62265)
    10:35:41.211 CallLeg::setRemoteSdp Remote SDP is set for legC:155.2
    10:35:41.211 Line::printEndpointInfo [CM505003]: Provider:[voipunlimited01702520020] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] Transport: [sip:10.14.3.8:5060]
    10:35:41.211 CallCtrl::onAnsweredCall [CM503002]: Call(155): Alerting sip:01702520020@sip.voip-unlimited.net:5060
    10:35:35.976 MediaServerReporting::SetRemoteParty [MS210002] C:155.2:Offer provided. Connection(transcoding mode): 81.130.211.188:9002(9003)
    10:35:35.789 CallCtrl::onSelectRouteReq [CM503004]: Call(155): Calling: VoIPline:07770381098@(Ln.10001@voipunlimited01702520020)@[Dev:sip:01702520020@sip.voip-unlimited.net:5060]
    10:35:35.789 CallCtrl::onSelectRouteReq [CM503010]: Making route(s) to [sip:07770381098@10.14.3.8:5060;user=phone]
    10:35:35.789 MediaServerReporting::SetRemoteParty [MS210000] C:155.1:Offer received. RTP connection: 10.14.3.43:52122(52123)
    10:35:35.789 CallLeg::setRemoteSdp Remote SDP is set for legC:155.1
    10:35:35.789 Extension::printEndpointInfo [CM505001]: Ext.13: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom300/7.3.7] Transport: [sip:10.14.3.8:5060]
    10:35:35.789 CallCtrl::onIncomingCall [CM503001]: Call(155): Incoming call from Ext.13 to [sip:07770381098@10.14.3.8:5060;user=phone]
    10:35:35.789 CallLeg::onNewCall [CM500002]: Info on incoming INVITE:
    INVITE sip:07770381098@10.14.3.8:5060;user=phone SIP/2.0
    Via: SIP/2.0/UDP 10.14.3.43:2048;branch=z9hG4bK-8uc76414hwqx;rport=2048
    Max-Forwards: 70
    Contact: [sip:13@10.14.3.43:2048;line=gzqzgbyc];reg-id=1
    To: [sip:07770381098@10.14.3.8:5060;user=phone]
    Call-ID: 3c2689f69763-iwg6ytw2eb1l
    CSeq: 2 INVITE
    Min-SE: 90
    Proxy-Authorization: Digest username="13",realm="3CXPhoneSystem",nonce="12875020535:683247bc1baa18d94dad33389751305e",uri="sip:07770381098@10.14.3.8:5060;user=phone",response="788e269a6a3a7e17a69bde41c411f388",algorithm=MD5
    Content-Length: 0
    10:34:13.664 Call::Terminate [CM503008]: Call(154): Call is terminated
    10:34:13.664 LineCfg::getInboundTarget [CM503012]: Inbound out-of-office hours' rule for LN:10002 forwards to DN:80
    10:34:13.664 LineCfg::getInboundTarget Looking for inbound target: called=00441702668298; caller=01603746925
    10:34:13.648 LineCfg::getInboundTarget Looking for inbound target: called=00441702668298; caller=01603746925
    10:34:13.648 Call::Terminate [CM503008]: Call(154): Call is terminated
    10:34:13.648 LineCfg::getInboundTarget [CM503012]: Inbound out-of-office hours' rule for LN:10002 forwards to DN:80
    10:32:55.039 CallLeg::onConfirmed Session 24473 of leg C:154.1 is confirmed
    10:32:54.867 CallCtrl::onLegConnected [CM503007]: Call(154): Device joined: sip:13@10.14.3.43:2048;line=gzqzgbyc
    10:32:54.867 LineCfg::getInboundTarget [CM503012]: Inbound out-of-office hours' rule for LN:10002 forwards to DN:80
    10:32:54.867 LineCfg::getInboundTarget Looking for inbound target: called=00441702668298; caller=01603746925
    10:32:54.867 CallCtrl::onLegConnected [CM503007]: Call(154): Device joined: sip:01603746925@217.10.69.13
    10:32:54.867 MediaServerReporting::SetRemoteParty [MS210003] C:154.1:Answer provided. Connection(transcoding mode):81.130.211.188:9000(9001)
    10:32:54.851 Call::RecordCall [CM503020]: Call(154): Call recording is started, audio file: ..\Data\Recordings\[01603746925]_01603746925-80_20081229103254(154).wav
    10:32:54.836 MediaServerReporting::SetRemoteParty [MS210001] C:154.7:Answer received. RTP connection: 10.14.3.43:51002(51003)
    10:32:54.836 CallLeg::setRemoteSdp Remote SDP is set for legC:154.7
    10:32:51.554 Call::Terminate [CM503008]: Call(153): Call is terminated
    10:32:51.554 LineCfg::getInboundTarget [CM503012]: Inbound out-of-office hours' rule for LN:10002 forwards to DN:80
    10:32:51.554 LineCfg::getInboundTarget Looking for inbound target: called=00441702668298; caller=07946255665
    10:32:51.539 LineCfg::getInboundTarget Looking for inbound target: called=00441702668298; caller=07946255665
    10:32:51.539 Call::Terminate [CM503008]: Call(153): Call is terminated
    10:32:51.539 LineCfg::getInboundTarget [CM503012]: Inbound out-of-office hours' rule for LN:10002 forwards to DN:80
    10:32:48.273 Extension::printEndpointInfo [CM505001]: Ext.55: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom300/7.1.30] Transport: [sip:10.14.3.8:5060]
    10:32:48.273 CallCtrl::onAnsweredCall [CM503002]: Call(154): Alerting sip:55@10.14.4.21:2048;line=ehi4l23a
    10:32:48.211 Extension::printEndpointInfo [CM505001]: Ext.11: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom300/7.1.30] Transport: [sip:10.14.3.8:5060]
    10:32:48.211 CallCtrl::onAnsweredCall [CM503002]: Call(154): Alerting sip:11@10.14.3.41:2048;line=t4pt0b29
    10:32:48.148 CallLeg::onFailure [CM503003]: Call(154): Call to sip:60@10.14.3.8:5060 has failed; Cause: 480 Do Not Disturb; from IP:10.14.3.231:1025
    10:32:48.133 Extension::printEndpointInfo [CM505001]: Ext.14: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom300/7.3.7] Transport: [sip:10.14.3.8:5060]
    10:32:48.133 CallCtrl::onAnsweredCall [CM503002]: Call(154): Alerting sip:14@10.14.3.44:2048;line=wmr13te0
    10:32:47.992 Extension::printEndpointInfo [CM505001]: Ext.18: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom300/7.3.7] Transport: [sip:10.14.3.8:5060]
    10:32:47.992 CallCtrl::onAnsweredCall [CM503002]: Call(154): Alerting sip:18@10.14.3.48:2048;line=2fl73ri4
    10:32:47.992 Extension::printEndpointInfo [CM505001]: Ext.16: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom300/7.1.30] Transport: [sip:10.14.3.8:5060]
    10:32:47.992 CallCtrl::onAnsweredCall [CM503002]: Call(154): Alerting sip:16@10.14.3.46:2048;line=3swx7pm6
    10:32:47.883 Extension::printEndpointInfo [CM505001]: Ext.10: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom300/7.3.7] Transport: [sip:10.14.3.8:5060]
    10:32:47.883 CallCtrl::onAnsweredCall [CM503002]: Call(154): Alerting sip:10@10.14.3.40:2048;line=pczpmvxq
    10:32:47.820 Extension::printEndpointInfo [CM505001]: Ext.12: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom300/7.1.30] Transport: [sip:10.14.3.8:5060]
    10:32:47.820 CallCtrl::onAnsweredCall [CM503002]: Call(154): Alerting sip:12@10.14.3.42:2048;line=3xn3be6q
    10:32:47.820 Extension::printEndpointInfo [CM505001]: Ext.13: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom300/7.3.7] Transport: [sip:10.14.3.8:5060]
    10:32:47.820 CallCtrl::onAnsweredCall [CM503002]: Call(154): Alerting sip:13@10.14.3.43:2048;line=gzqzgbyc
    10:32:47.804 Extension::printEndpointInfo [CM505001]: Ext.17: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom300/7.3.7] Transport: [sip:10.14.3.8:5060]
    10:32:47.804 CallCtrl::onAnsweredCall [CM503002]: Call(154): Alerting sip:17@10.14.3.17:2048;line=iaqk5c1c
    10:32:47.711 MediaServerReporting::SetRemoteParty [MS210002] C:154.12:Offer provided. Connection(transcoding mode): 10.14.3.8:7114(7115)
    10:32:47.695 MediaServerReporting::SetRemoteParty [MS210002] C:154.11:Offer provided. Connection(transcoding mode): 10.14.3.8:7112(7113)
    10:32:47.695 MediaServerReporting::SetRemoteParty [MS210002] C:154.10:Offer provided. Connection(transcoding mode): 10.14.3.8:7110(7111)
    10:32:47.695 MediaServerReporting::SetRemoteParty [MS210002] C:154.9:Offer provided. Connection(transcoding mode): 10.14.3.8:7108(7109)
    10:32:47.695 MediaServerReporting::SetRemoteParty [MS210002] C:154.8:Offer provided. Connection(transcoding mode): 10.14.3.8:7106(7107)
    10:32:47.679 MediaServerReporting::SetRemoteParty [MS210002] C:154.7:Offer provided. Connection(transcoding mode): 10.14.3.8:7104(7105)
    10:32:47.679 MediaServerReporting::SetRemoteParty [MS210002] C:154.6:Offer provided. Connection(transcoding mode): 10.14.3.8:7102(7103)
    10:32:47.679 MediaServerReporting::SetRemoteParty [MS210002] C:154.5:Offer provided. Connection(transcoding mode): 10.14.3.8:7100(7101)
    10:32:47.664 MediaServerReporting::SetRemoteParty [MS210002] C:154.4:Offer provided. Connection(transcoding mode): 10.14.3.8:7098(7099)
    10:32:47.664 MediaServerReporting::SetRemoteParty [MS210002] C:154.3:Offer provided. Connection(transcoding mode): 10.14.3.8:7096(7097)
    10:32:47.664 MediaServerReporting::SetRemoteParty [MS210002] C:154.2:Offer provided. Connection(transcoding mode): 10.14.3.8:7094(7095)
    10:32:47.664 CallCtrl::onSelectRouteReq [CM503004]: Call(154): Calling: RingAll80:10Ext.1011Ext.1112Ext.1215Ext.1514Ext.1418Ext.1813Ext.1316Ext.1617Ext.1720Ext.2051Ext.5119Ext.1950Ext.5060Ext.6055Ext.55@[Dev:sip:10@10.14.3.40:2048;line=pczpmvxq, Dev:sip:11@10.14.3.41:2048;line=t4pt0b29, Dev:sip:12@10.14.3.42:2048;line=3xn3be6q, Dev:sip:14@10.14.3.44:2048;line=wmr13te0, Dev:sip:18@10.14.3.48:2048;line=2fl73ri4, Dev:sip:13@10.14.3.43:2048;line=gzqzgbyc, Dev:sip:16@10.14.3.46:2048;line=3swx7pm6, Dev:sip:17@10.14.3.17:2048;line=iaqk5c1c, Dev:sip:20@10.14.3.49, Dev:sip:60@10.14.3.231:1025;line=vq9j1o1w, Dev:sip:55@10.14.4.21:2048;line=ehi4l23a]
    10:32:47.648 CallCtrl::onSelectRouteReq [CM503010]: Making route(s) to [sip:80@sip.branch01.djsuperstore.co.uk:5060]
    10:32:47.648 MediaServerReporting::SetRemoteParty [MS210000] C:154.1:Offer received. RTP connection: 217.10.77.23:52842(52843)
    10:32:47.648 CallLeg::setRemoteSdp Remote SDP is set for legC:154.1
    10:32:47.648 Line::printEndpointInfo [CM505003]: Provider:[Sip Gate] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] Transport: [sip:10.14.3.8:5060]
    10:32:47.648 LineCfg::getInboundTarget [CM503012]: Inbound out-of-office hours' rule for LN:10002 forwards to DN:80
    10:32:47.648 LineCfg::getInboundTarget Looking for inbound target: called=00441702668298; caller=01603746925
    10:32:47.648 CallCtrl::onIncomingCall [CM503001]: Call(154): Incoming call from 01603746925@(Ln.10002@Sip Gate) to [sip:80@sip.branch01.djsuperstore.co.uk:5060]
    10:32:47.523 LineCfg::getInboundTarget [CM503012]: Inbound out-of-office hours' rule for LN:10002 forwards to DN:80
    10:32:47.523 LineCfg::getInboundTarget Looking for inbound target: called=00441702668298; caller=01603746925
    10:32:47.508 CallLeg::onNewCall [CM500002]: Info on incoming INVITE:
    INVITE sip:2668298@81.130.211.188:5060;rinstance=da4304694c2bd978 SIP/2.0
    Via: SIP/2.0/UDP 217.10.79.23:5060;branch=z9hG4bKbf5e.86a1b874.0
    Via: SIP/2.0/UDP 172.20.40.4;branch=z9hG4bKbf5e.86a1b874.0
    Via: SIP/2.0/UDP 217.10.79.23:5060;received=217.10.68.6;branch=z9hG4bK310483e6
    Via: SIP/2.0/UDP 217.10.69.13:5060;branch=z9hG4bK310483e6;rport=5060
    Max-Forwards: 67
    Record-Route: [sip:217.10.79.23;lr=on;ftag=as5b7ffe7f]
    Record-Route: [sip:172.20.40.4;lr=on]
    Contact: [sip:01603746925@217.10.69.13]
    To: [sip:00441702668298@sipgate.co.uk]
    From: "01603746925"[sip:01603746925@sipgate.co.uk];tag=as5b7ffe7f
    Call-ID: 795182867d0ce6b411b87c207f9440cd@sipgate.co.uk
    CSeq: 102 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY
    Supported: replaces
    Content-Length: 0
    10:32:12.648 StunClient::onInitTests [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 75.101.138.128:3478 over Transport 10.14.3.8:5060
    10:30:20.476 MediaServerReporting::SetRemoteParty [MS210003] C:153.7:Answer provided. Connection(transcoding mode):10.14.3.8:7082(7083)
    10:30:20.476 MediaServerReporting::SetRemoteParty [MS210000] C:153.7:Offer received. RTP connection: 10.14.3.43:65124(65125)
    10:30:20.476 CallLeg::setRemoteSdp Remote SDP is set for legC:153.7
    10:30:05.070 MediaServerReporting::SetRemoteParty [MS210003] C:153.7:Answer provided. Connection(transcoding mode):10.14.3.8:7082(7083)
    10:30:05.070 MediaServerReporting::SetRemoteParty [MS210000] C:153.7:Offer received. RTP connection: 10.14.3.43:65124(65125)
    10:30:05.070 CallLeg::setRemoteSdp Remote SDP is set for legC:153.7
    10:29:56.961 CallLeg::onConfirmed Session 24429 of leg C:153.1 is confirmed
    10:29:56.804 CallCtrl::onLegConnected [CM503007]: Call(153): Device joined: sip:13@10.14.3.43:2048;line=gzqzgbyc
    10:29:56.804 LineCfg::getInboundTarget [CM503012]: Inbound out-of-office hours' rule for LN:10002 forwards to DN:80
    10:29:56.804 LineCfg::getInboundTarget Looking for inbound target: called=00441702668298; caller=07946255665
    10:29:56.804 CallCtrl::onLegConnected [CM503007]: Call(153): Device joined: sip:07946255665@217.10.66.71
    10:29:56.804 MediaServerReporting::SetRemoteParty [MS210003] C:153.1:Answer provided. Connection(transcoding mode):81.130.211.188:9014(9015)
    10:29:56.789 Call::RecordCall [CM503020]: Call(153): Call recording is started, audio file: ..\Data\Recordings\[07946255665]_07946255665-80_20081229102956(153).wav
    10:29:56.773 MediaServerReporting::SetRemoteParty [MS210001] C:153.7:Answer received. RTP connection: 10.14.3.43:65124(65125)
    10:29:56.773 CallLeg::setRemoteSdp Remote SDP is set for legC:153.7
    10:29:48.789 Extension::printEndpointInfo [CM505001]: Ext.11: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom300/7.1.30] Transport: [sip:10.14.3.8:5060]
    10:29:48.789 CallCtrl::onAnsweredCall [CM503002]: Call(153): Alerting sip:11@10.14.3.41:2048;line=t4pt0b29
    10:29:48.726 Extension::printEndpointInfo [CM505001]: Ext.55: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom300/7.1.30] Transport: [sip:10.14.3.8:5060]
    10:29:48.726 CallCtrl::onAnsweredCall [CM503002]: Call(153): Alerting sip:55@10.14.4.21:2048;line=ehi4l23a
    10:29:48.711 Extension::printEndpointInfo [CM505001]: Ext.14: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom300/7.3.7] Transport: [sip:10.14.3.8:5060]
    10:29:48.711 CallCtrl::onAnsweredCall [CM503002]: Call(153): Alerting sip:14@10.14.3.44:2048;line=wmr13te0
    10:29:48.679 CallLeg::onFailure [CM503003]: Call(153): Call to sip:60@10.14.3.8:5060 has failed; Cause: 480 Do Not Disturb; from IP:10.14.3.231:1025
    10:29:48.586 Extension::printEndpointInfo [CM505001]: Ext.18: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom300/7.3.7] Transport: [sip:10.14.3.8:5060]
    10:29:48.586 CallCtrl::onAnsweredCall [CM503002]: Call(153): Alerting sip:18@10.14.3.48:2048;line=2fl73ri4
    10:29:48.570 Extension::printEndpointInfo [CM505001]: Ext.16: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom300/7.1.30] Transport: [sip:10.14.3.8:5060]
    10:29:48.570 CallCtrl::onAnsweredCall [CM503002]: Call(153): Alerting sip:16@10.14.3.46:2048;line=3swx7pm6
    10:29:48.461 Extension::printEndpointInfo [CM505001]: Ext.10: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom300/7.3.7] Transport: [sip:10.14.3.8:5060]
    10:29:48.461 CallCtrl::onAnsweredCall [CM503002]: Call(153): Alerting sip:10@10.14.3.40:2048;line=pczpmvxq
    10:29:48.398 Extension::printEndpointInfo [CM505001]: Ext.12: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom300/7.1.30] Transport: [sip:10.14.3.8:5060]
    10:29:48.398 CallCtrl::onAnsweredCall [CM503002]: Call(153): Alerting sip:12@10.14.3.42:2048;line=3xn3be6q
    10:29:48.383 Extension::printEndpointInfo [CM505001]: Ext.13: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom300/7.3.7] Transport: [sip:10.14.3.8:5060]
    10:29:48.383 CallCtrl::onAnsweredCall [CM503002]: Call(153): Alerting sip:13@10.14.3.43:2048;line=gzqzgbyc
    10:29:48.383 Extension::printEndpointInfo [CM505001]: Ext.17: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom300/7.3.7] Transport: [sip:10.14.3.8:5060]
    10:29:48.383 CallCtrl::onAnsweredCall [CM503002]: Call(153): Alerting sip:17@10.14.3.17:2048;line=iaqk5c1c
    10:29:48.273 MediaServerReporting::SetRemoteParty [MS210002] C:153.12:Offer provided. Connection(transcoding mode): 10.14.3.8:7092(7093)
    10:29:48.273 MediaServerReporting::SetRemoteParty [MS210002] C:153.11:Offer provided. Connection(transcoding mode): 10.14.3.8:7090(7091)
    10:29:48.273 MediaServerReporting::SetRemoteParty [MS210002] C:153.10:Offer provided. Connection(transcoding mode): 10.14.3.8:7088(7089)
    10:29:48.273 MediaServerReporting::SetRemoteParty [MS210002] C:153.9:Offer provided. Connection(transcoding mode): 10.14.3.8:7086(7087)
    10:29:48.258 MediaServerReporting::SetRemoteParty [MS210002] C:153.8:Offer provided. Connection(transcoding mode): 10.14.3.8:7084(7085)
    10:29:48.258 MediaServerReporting::SetRemoteParty [MS210002] C:153.7:Offer provided. Connection(transcoding mode): 10.14.3.8:7082(7083)
    10:29:48.258 MediaServerReporting::SetRemoteParty [MS210002] C:153.6:Offer provided. Connection(transcoding mode): 10.14.3.8:7080(7081)
    10:29:48.258 MediaServerReporting::SetRemoteParty [MS210002] C:153.5:Offer provided. Connection(transcoding mode): 10.14.3.8:7078(7079)
  15. worksighted
    Aug 19, 2008
    204
    What kind of phones are you using? Can you check the audio codec being used on each phone?
    Mike
  16. Nebula
    Nebula New Member
    Apr 6, 2008
    116
    I think part of your problem here cold be the subnet mask you are using. If I have read this thread correctly you are using a class A subnet, 255.0.0.0 with this setup both locations will been seen as the same network dispite the 3rd octet being different. I think you should be using a class C mask, 255.255.255.0 without this you will have routing issues between the sites.
  17. worksighted
    Aug 19, 2008
    204
    Your masking is OK. You are a mask of 255.0.0.0 which means only the first octet must match to be on the same subnet. You are using bridged vpn (not routed) so I think you should be OK on this piece since you want them to appear as a contiguous subnet.
    Mike
  18. qlxltd
    Nov 3, 2008
    25
    Using Snom 300's
    How do I find the codecs in use?
  19. kevin
    kevin Member
    Nov 23, 2006
    316
    Hi there
    If you could attach a Wireshark capture running on the PBX that shows this single failure, maybe I can look at it and give you some pointers.
    Please do a "route print" and "ipconfig /all" on the PBX machine and attach also.
    Regards
    Kevin
