One way audio with Queues
Discussion in '3CX Phone System - General' started by sdavies68, Feb 9, 2010.
  1. sdavies68
    Jan 26, 2010
    21
    I have setup a Call queue. The queue works, but I get a one way audio problem and cannot discover any reason why it is occurring.
    The direction of the audio problem is from the handset logged into the queue I can receive the audio from inbound caller, but when sending audio out from the handset the inbound caller does not receive anything.
    Firewall has checked out ok and passed its tests.
    Here is the log from 3CX
    10:42:04.640 [CM503008]: Call(15): Call is terminated
    10:41:47.359 [MS105000] C:15.1: No RTP packets were received:remoteAddr=127.0.0.1:40630,extAddr=0.0.0.0:0,localAddr=127.0.0.1:7058
    10:41:47.171 [MS210003] C:15.2:Answer provided. Connection(transcoding mode[unsecure]):172.31.253.10:7060(7061)
    10:41:47.171 [MS210000] C:15.2:Offer received. RTP connection: 172.31.245.42:51840(51841)
    10:41:47.171 Remote SDP is set for legC:15.2
    10:41:46.937 [CM503008]: Call(14): Call is terminated
    10:41:46.921 Relpaces: ZTZhYzUwMGE3NzdlNTg5NDE4MTkwZmEzNTllYmJiMTI.;to-tag=cf094574;from-tag=c674474e
    10:41:46.921 Refer: from="0409029282"<sip:0409029282@127.0.0.1:5060>;tag=f31dac15; to=<sip:Q803@127.0.0.1:5060>;tag=2d14d210; RefTo="0409029282"<sip:0409029282@127.0.0.1:5060?Replaces=ZTZhYzUwMGE3NzdlNTg5NDE4MTkwZmEzNTllYmJiMTI.%3Bto-tag%3Dcf094574%3Bfrom-tag%3Dc674474e>;tag=cf094574
    10:41:46.921 Session 5629 of leg C:15.1 is confirmed
    10:41:46.703 [CM503007]: Call(15): Device joined: sip:111@172.31.245.42:13278;rinstance=058fc27c7a6cf49a;transport=udp
    10:41:46.703 [CM503007]: Call(15): Device joined: sip:803@127.0.0.1:40600;rinstance=ed353bad47fb726e
    10:41:46.703 [MS210005] C:15.1:Answer provided. Connection(proxy mode):127.0.0.1:7058(7059)
    10:41:46.687 [MS210001] C:15.2:Answer received. RTP connection[unsecure]: 172.31.245.42:51840(51841)
    10:41:46.687 Remote SDP is set for legC:15.2
    10:41:45.250 [CM505001]: Ext.111: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [CP PAO 2.0.2.196] PBX contact: [sip:111@172.31.253.10:5060]
    10:41:45.250 [CM503002]: Call(15): Alerting sip:111@172.31.245.42:13278;rinstance=058fc27c7a6cf49a;transport=udp
    10:41:44.968 [CM503025]: Call(15): Calling Queue803:111Ext.111@[Dev:sip:111@172.31.245.42:13278;rinstance=058fc27c7a6cf49a;transport=udp]
    10:41:44.968 [MS210004] C:15.2:Offer provided. Connection(proxy mode): 172.31.253.10:7060(7061)
    10:41:44.921 [CM503004]: Call(15): Route 1: Queue803:111Ext.111@[Dev:sip:111@172.31.245.42:13278;rinstance=058fc27c7a6cf49a;transport=udp]
    10:41:44.921 [CM503010]: Making route(s) to <sip:Q803@127.0.0.1:5060>
    10:41:44.921 [MS210000] C:15.1:Offer received. RTP connection: 127.0.0.1:40630(40631)
    10:41:44.906 Remote SDP is set for legC:15.1
    10:41:44.906 [CM505001]: Ext.803: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Queue] PBX contact: [sip:803@127.0.0.1:5060]
    10:41:44.906 [CM503001]: Call(15): Incoming call from Ext.803 to <sip:Q803@127.0.0.1:5060>
    10:41:44.906 [CM500002]: Info on incoming INVITE:
    INVITE sip:Q803@127.0.0.1:5060 SIP/2.0
    Via: SIP/2.0/UDP 127.0.0.1:40600;branch=z9hG4bK-d8754z-a22cf8703d03c115-1---d8754z-;rport=40600
    Max-Forwards: 70
    Contact: <sip:803@127.0.0.1:40600;rinstance=ed353bad47fb726e>
    To: <sip:Q803@127.0.0.1:5060>
    From: "0409029282"<sip:0409029282@127.0.0.1:5060>;tag=f31dac15
    Call-ID: MDQzNmYxYWI1ODY4ZGI2NDBjMTZmODMxM2QyMmQyOTI.
    CSeq: 2 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO
    Proxy-Authorization: Digest username="803",realm="3CXPhoneSystem",nonce="414d535c018283b814:05f5f2d5e2e6eebaa66256d8e58a35de",uri="sip:Q803@127.0.0.1:5060",response="3dd2922bd6c65f82b70ce6adf0e595fa",algorithm=MD5
    Supported: replaces
    User-Agent: 3CX Queue
    Content-Length: 0
    10:41:44.578 [CM503007]: Call(14): Device joined: sip:803@127.0.0.1:40600;rinstance=ed353bad47fb726e
    10:41:44.578 [MS210003] C:14.3:Answer provided. Connection(transcoding mode[unsecure]):127.0.0.1:7056(7057)
    10:41:44.578 [MS210002] C:14.1:Offer provided. Connection(transcoding mode): 210.50.3.28:9012(9013)
    10:41:44.578 [MS210000] C:14.3:Offer received. RTP connection: 127.0.0.1:40628(40629)
    10:41:44.578 Remote SDP is set for legC:14.3
    10:41:44.578 [CM505001]: Ext.803: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Queue] PBX contact: [sip:803@127.0.0.1:5060]
    10:41:44.578 [CM503002]: Call(14): Alerting sip:803@127.0.0.1:40600;rinstance=ed353bad47fb726e
    10:41:44.421 [CM503025]: Call(14): Calling Ext:Ext.803@[Dev:sip:803@127.0.0.1:40600;rinstance=ed353bad47fb726e]
    10:41:44.375 [CM503004]: Call(14): Route 1: Ext:Ext.803@[Dev:sip:803@127.0.0.1:40600;rinstance=ed353bad47fb726e]
    10:41:44.375 [CM503010]: Making route(s) to <sip:803@127.0.0.1:5060>
    10:41:44.375 [CM505003]: Provider:[MyNetFone-01] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [ENSR2.5.4] PBX contact: [sip:09214936@210.50.3.28:5060]
    10:41:44.375 Refer: from=<sip:800@127.0.0.1:5060>;tag=87197d46; to="0409029282"<sip:0409029282@127.0.0.1:5060>;tag=a95bee72; RefTo=<sip:803@127.0.0.1:5060>
    10:41:44.171 [MS210003] C:14.2:Answer provided. Connection(transcoding mode[unsecure]):127.0.0.1:7054(7055)
    10:41:44.171 [MS210000] C:14.2:Offer received. RTP connection: 127.0.0.1:40626(40627)
    10:41:44.171 Remote SDP is set for legC:14.2
    10:41:39.156 [MS211000] C:14.1: 125.213.160.79:24954 is delivering DTMF using RTP payload (RFC2833). In-Band DTMF tone detection is disabled for this call segment.
    10:41:35.468 Session 5619 of leg C:14.1 is confirmed
    10:41:35.125 [CM503007]: Call(14): Device joined: sip:800@127.0.0.1:40600;rinstance=80066a81e15fd9e9
    10:41:35.125 [CM503007]: Call(14): Device joined: sip:09214936@sip00.mynetfone.com.au:5060
    10:41:35.125 [MS210003] C:14.1:Answer provided. Connection(transcoding mode[unsecure]):210.50.3.28:9012(9013)
    10:41:35.125 [MS210001] C:14.2:Answer received. RTP connection[unsecure]: 127.0.0.1:40626(40627)
    10:41:35.125 Remote SDP is set for legC:14.2
    10:41:35.125 [CM505001]: Ext.800: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX IVR] PBX contact: [sip:800@127.0.0.1:5060]
    10:41:35.125 [CM503002]: Call(14): Alerting sip:800@127.0.0.1:40600;rinstance=80066a81e15fd9e9
    10:41:34.968 [CM503025]: Call(14): Calling Ext:Ext.800@[Dev:sip:800@127.0.0.1:40600;rinstance=80066a81e15fd9e9]
    10:41:34.968 [MS210002] C:14.2:Offer provided. Connection(transcoding mode): 127.0.0.1:7054(7055)
    10:41:34.953 [CM503004]: Call(14): Route 1: Ext:Ext.800@[Dev:sip:800@127.0.0.1:40600;rinstance=80066a81e15fd9e9]
    10:41:34.953 [CM503010]: Making route(s) to <sip:800@172.31.253.10:5060>
    10:41:34.953 [MS210000] C:14.1:Offer received. RTP connection: 125.213.160.79:24954(24955)
    10:41:34.937 Remote SDP is set for legC:14.1
    10:41:34.937 [CM505003]: Provider:[MyNetFone-01] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [ENSR2.5.4] PBX contact: [sip:09214936@210.50.3.28:5060]
    10:41:34.937 [CM503001]: Call(14): Incoming call from 0409029282@(Ln.10001@MyNetFone-01) to <sip:800@172.31.253.10:5060>
    10:41:34.921 [CM503012]: Inbound office hours rule (unnamed) for 10001 forwards to DN:800
    10:41:34.921 Looking for inbound target: called=09214936; caller=0409029282
    10:41:34.921 [CM500002]: Info on incoming INVITE:
    INVITE sip:09214936@172.31.253.10:5060;user=phone SIP/2.0
    Via: SIP/2.0/UDP 125.213.160.81:5060;branch=z9hG4bK17dd5a0514b71f2cc-169b9-0
    Max-Forwards: 70
    Contact: <sip:0409029282@125.213.160.81:5060>
    To: <sip:09214936@172.31.253.10:5060>
    From: "0409029282"<sip:0409029282@125.213.160.81:5060>;tag=4df13903-co926-INS001
    Call-ID: 3477-4d7-19201023424-img-01-mas-0-125.213.168.3
    CSeq: 92601 INVITE
    Supported: 100rel
    User-Agent: ENSR2.5.4
    Content-Length: 0
    Diversion: <sip:61872003337@125.213.160.81>;reason=unconditional
    Its saying it cannot receive the RTP String
    But that is coming from the localhost back on itself.
  2. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    basically you need to get the extension/s and bind to media server. and see how it goes.
    Steps-
    Select an extension/s, go to Other and uncheck Re-invite and Replaces.
    Then check for PBX delivers audio and select Apply /Ok, and see how it goes.
  3. sdavies68
    Jan 26, 2010
    21
    I still have the same problem.
    i followed your instructions
    * set the PBX delivers audio to on
    * set Supports re-invite off
    * set supports replace header off
    But when lookin at the log I still see this
    Why is it still showing capabilities having reinvite, replaces when the are turned off on this extension.
    I am running version 8.0.9941.549
  4. sdavies68
    Jan 26, 2010
    21
    Any further response to my problem.
    I have just paid $750 for the full version to get this feature and its not working.
  5. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Could you please specify following information:
    1. OS
    2. Provider
    3. Equipment
    4. NAT (firewall) device
    5. How it is specified in PBX configuration?
    See http://www.3cx.com/forums/forum-rules-read-to-get-answers-93.html for details.
  6. sdavies68
    Jan 26, 2010
    21
    First I start with the forum rules.
    Your manual sucks, so if you are going to provide a system with such poor documenation you should at least include 30 days initital support. So posting here is the only option, because I am not going to also purchase commercial support for a product which is so badly documented.
    You have a great product, just poor documentation.
    1. Windows Small Business Server 2003
    2. MyNetFone
    3. Dell Server, handsets are Cisco 7912G and also Bria for Outlook, as well as the 3CX client, all are the same problem.
    4. Cisco IOS. Have configured all the NAT settings as required and the Firewall checker passes 100% in all phases
    5. How is what specified int he PBX configuration
  7. SY
    3CX Support
    Jan 26, 2007
    1,825
    Sorry, I don't plan to discuss bugs in PBX and quality of your equipment. I've tried to ask you to specify the equipment and specify how it is configured for PBX (in magement console)
    Excuse me for disturbance...
  8. sdavies68
    Jan 26, 2010
    21
    Queue is setup as follows:
    All default settings except announce queue position to call.
    The queue is working fine, and audio is work by directionally at this stage. That is DTMF from the caller is sent to the PBX, and the announcement back out is received by the caller.
    The problem occurs when the extension answers the queued call. I get the no RTP stream in the system log and while I can hear the caller, the caller cannot hear me.
    The extension is setup as default with the exception as recommend by 3CX in others tab
    PBX delivers audio - checked
    supports re-invite - not checked
    supports replace - not check
    Same configuration on the VoIP provider
  9. sdavies68
    Jan 26, 2010
    21
    Has anyone tested Queues and got them working?
    Also when I place the caller on hold using the 3CX client, audio starts working again and the caller receives the onhold music.
