One way Audio
Discussion in '3CX Phone System - General' started by smontano, Jan 3, 2010.
  1. smontano
    Jan 3, 2010
    5
    One way audio problem. Im using as voip gateway SAP3102 FXO for PSTN and FXS for internal extension.
    My 3cx server is behind a linksys router WRT54GL as well as my SAP3102. Im able to inbound/oubound from VOIP to PSTN and viceversa.
    On my WRT54GL i forwarded RTP ports (10000-20000).
    On my 3CX, under network (external) i specified 10000 to 20000, under internal 7000 - 7499
    I have in another site a Linksys PAP2, this is able to register to my 3CX. When i call from my internal extension E.I. 101 to this external PAP2 E.I. 102, they can hear me, but i cant hear them.
    My local subnet is 172.16.1.0/28.
    On the server logs, theres no RTP packets. but i do see im using port 7001, instead of 10000 to 20000. I modified the 3CXphonesystem.ini file adding [Network] LocalSubnets=172.16.1.0/28. But seems it doesnt take it.
    Does sombody has an idea?
  2. smontano
    Jan 3, 2010
    5
    I forgot to add:
    All my setup works perfect with asterisk, i just want to give a try with 3CX. I also played with re-invite and PBX audio options. I disabled my windows firewall. Im almost 100% sure is 3CX bug and not a port forward issue.
    Im using a DDNS so my external ATA can connect to my PBX server. STUN server is able to resolve my DDNS.
    Ideas?
  3. dab
    dab
    Nov 1, 2009
    67
    What say's the 3CX "Firewall Checker"?
  4. smontano
    Jan 3, 2010
    5
    I just did the test for ports between 10000 and 10100 (for 20000, displays a lot =) ):
    3CX Firewall Checker, v1.0. Copyright (C) 3CX Ltd. All rights reserved.
    <14:08:56>: Phase 1, checking servers connection, please wait...
    <14:08:56>: Stun Checker service is reachable. Phase 1 check passed.
    <14:08:56>: Phase 2a, Check Port Forwarding to UDP SIP port, please wait...
    <14:08:57>: UDP SIP Port is set to 5060. Response received correctly with no translation. Phase 2a check passed.
    <14:08:57>: Phase 2b. Check Port Forwarding to TCP SIP port, please wait...
    <14:08:57>: TCP SIP Port is set to 5060. Response received correctly with no translation. Phase 2b check passed.
    <14:08:57>: Phase 3. Check Port Forwarding to TCP Tunnel port, please wait...
    <14:08:58>: TCP TUNNEL Port is set to 5090. Response received correctly with no translation. Phase 3 check passed.
    <14:08:58>: Phase 4. Check Port Forwarding to RTP external port range, please wait...
    <14:09:10>: UDP RTP Port 10000. Response received correctly with no translation. Phase 4-01 check passed.
    <14:09:10>: UDP RTP Port 10001. Response received correctly with no translation. Phase 4-02 check passed.
    <14:09:10>: UDP RTP Port 10002. Response received correctly with no translation. Phase 4-03 check passed.
    <14:09:10>: UDP RTP Port 10003. Response received correctly with no translation. Phase 4-04 check passed.
    <14:09:10>: UDP RTP Port 10004. Response received correctly with no translation. Phase 4-05 check passed.
    <14:09:10>: UDP RTP Port 10005. Response received correctly with no translation. Phase 4-06 check passed.
    <14:09:10>: UDP RTP Port 10006. Response received correctly with no translation. Phase 4-07 check passed.
    <14:09:10>: UDP RTP Port 10007. Response received correctly with no translation. Phase 4-08 check passed.
    <14:09:10>: UDP RTP Port 10008. Response received correctly with no translation. Phase 4-09 check passed.
    <14:09:10>: UDP RTP Port 10009. Response received correctly with no translation. Phase 4-10 check passed.
    <14:09:10>: UDP RTP Port 10010. Response received correctly with no translation. Phase 4-11 check passed.
    <14:09:10>: UDP RTP Port 10011. Response received correctly with no translation. Phase 4-12 check passed.
    <14:09:10>: UDP RTP Port 10012. Response received correctly with no translation. Phase 4-13 check passed.
    <14:09:10>: UDP RTP Port 10013. Response received correctly with no translation. Phase 4-14 check passed.
    <14:09:10>: UDP RTP Port 10014. Response received correctly with no translation. Phase 4-15 check passed.
    <14:09:10>: UDP RTP Port 10015. Response received correctly with no translation. Phase 4-16 check passed.
    <14:09:10>: UDP RTP Port 10016. Response received correctly with no translation. Phase 4-17 check passed.
    <14:09:10>: UDP RTP Port 10017. Response received correctly with no translation. Phase 4-18 check passed.
    <14:09:10>: UDP RTP Port 10018. Response received correctly with no translation. Phase 4-19 check passed.
    <14:09:10>: UDP RTP Port 10019. Response received correctly with no translation. Phase 4-20 check passed.
    <14:09:10>: UDP RTP Port 10020. Response received correctly with no translation. Phase 4-21 check passed.
    <14:09:10>: UDP RTP Port 10021. Response received correctly with no translation. Phase 4-22 check passed.
    <14:09:10>: UDP RTP Port 10022. Response received correctly with no translation. Phase 4-23 check passed.
    <14:09:10>: UDP RTP Port 10023. Response received correctly with no translation. Phase 4-24 check passed.
    <14:09:10>: UDP RTP Port 10024. Response received correctly with no translation. Phase 4-25 check passed.
    <14:09:10>: UDP RTP Port 10025. Response received correctly with no translation. Phase 4-26 check passed.
    <14:09:10>: UDP RTP Port 10026. Response received correctly with no translation. Phase 4-27 check passed.
    <14:09:10>: UDP RTP Port 10027. Response received correctly with no translation. Phase 4-28 check passed.
    <14:09:10>: UDP RTP Port 10028. Response received correctly with no translation. Phase 4-29 check passed.
    <14:09:10>: UDP RTP Port 10029. Response received correctly with no translation. Phase 4-30 check passed.
    <14:09:10>: UDP RTP Port 10030. Response received correctly with no translation. Phase 4-31 check passed.
    <14:09:10>: UDP RTP Port 10031. Response received correctly with no translation. Phase 4-32 check passed.
    <14:09:10>: UDP RTP Port 10032. Response received correctly with no translation. Phase 4-33 check passed.
    <14:09:10>: UDP RTP Port 10033. Response received correctly with no translation. Phase 4-34 check passed.
    <14:09:10>: UDP RTP Port 10034. Response received correctly with no translation. Phase 4-35 check passed.
    <14:09:10>: UDP RTP Port 10035. Response received correctly with no translation. Phase 4-36 check passed.
    <14:09:10>: UDP RTP Port 10036. Response received correctly with no translation. Phase 4-37 check passed.
    <14:09:10>: UDP RTP Port 10037. Response received correctly with no translation. Phase 4-38 check passed.
    <14:09:10>: UDP RTP Port 10038. Response received correctly with no translation. Phase 4-39 check passed.
    <14:09:10>: UDP RTP Port 10039. Response received correctly with no translation. Phase 4-40 check passed.
    <14:09:10>: UDP RTP Port 10040. Response received correctly with no translation. Phase 4-41 check passed.
    <14:09:10>: UDP RTP Port 10041. Response received correctly with no translation. Phase 4-42 check passed.
    <14:09:10>: UDP RTP Port 10042. Response received correctly with no translation. Phase 4-43 check passed.
    <14:09:10>: UDP RTP Port 10043. Response received correctly with no translation. Phase 4-44 check passed.
    <14:09:10>: UDP RTP Port 10044. Response received correctly with no translation. Phase 4-45 check passed.
    <14:09:10>: UDP RTP Port 10045. Response received correctly with no translation. Phase 4-46 check passed.
    <14:09:10>: UDP RTP Port 10046. Response received correctly with no translation. Phase 4-47 check passed.
    <14:09:10>: UDP RTP Port 10047. Response received correctly with no translation. Phase 4-48 check passed.
    <14:09:10>: UDP RTP Port 10048. Response received correctly with no translation. Phase 4-49 check passed.
    <14:09:10>: UDP RTP Port 10049. Response received correctly with no translation. Phase 4-50 check passed.
    <14:09:10>: UDP RTP Port 10050. Response received correctly with no translation. Phase 4-51 check passed.
    <14:09:10>: UDP RTP Port 10051. Response received correctly with no translation. Phase 4-52 check passed.
    <14:09:10>: UDP RTP Port 10052. Response received correctly with no translation. Phase 4-53 check passed.
    <14:09:10>: UDP RTP Port 10053. Response received correctly with no translation. Phase 4-54 check passed.
    <14:09:10>: UDP RTP Port 10054. Response received correctly with no translation. Phase 4-55 check passed.
    <14:09:10>: UDP RTP Port 10055. Response received correctly with no translation. Phase 4-56 check passed.
    <14:09:10>: UDP RTP Port 10056. Response received correctly with no translation. Phase 4-57 check passed.
    <14:09:10>: UDP RTP Port 10057. Response received correctly with no translation. Phase 4-58 check passed.
    <14:09:10>: UDP RTP Port 10058. Response received correctly with no translation. Phase 4-59 check passed.
    <14:09:10>: UDP RTP Port 10059. Response received correctly with no translation. Phase 4-60 check passed.
    <14:09:10>: UDP RTP Port 10060. Response received correctly with no translation. Phase 4-61 check passed.
    <14:09:10>: UDP RTP Port 10061. Response received correctly with no translation. Phase 4-62 check passed.
    <14:09:10>: UDP RTP Port 10062. Response received correctly with no translation. Phase 4-63 check passed.
    <14:09:10>: UDP RTP Port 10063. Response received correctly with no translation. Phase 4-64 check passed.
    <14:09:10>: UDP RTP Port 10064. Response received correctly with no translation. Phase 4-65 check passed.
    <14:09:10>: UDP RTP Port 10065. Response received correctly with no translation. Phase 4-66 check passed.
    <14:09:10>: UDP RTP Port 10066. Response received correctly with no translation. Phase 4-67 check passed.
    <14:09:10>: UDP RTP Port 10067. Response received correctly with no translation. Phase 4-68 check passed.
    <14:09:10>: UDP RTP Port 10068. Response received correctly with no translation. Phase 4-69 check passed.
    <14:09:10>: UDP RTP Port 10069. Response received correctly with no translation. Phase 4-70 check passed.
    <14:09:10>: UDP RTP Port 10070. Response received correctly with no translation. Phase 4-71 check passed.
    <14:09:10>: UDP RTP Port 10071. Response received correctly with no translation. Phase 4-72 check passed.
    <14:09:10>: UDP RTP Port 10072. Response received correctly with no translation. Phase 4-73 check passed.
    <14:09:10>: UDP RTP Port 10073. Response received correctly with no translation. Phase 4-74 check passed.
    <14:09:10>: UDP RTP Port 10074. Response received correctly with no translation. Phase 4-75 check passed.
    <14:09:10>: UDP RTP Port 10075. Response received correctly with no translation. Phase 4-76 check passed.
    <14:09:10>: UDP RTP Port 10076. Response received correctly with no translation. Phase 4-77 check passed.
    <14:09:10>: UDP RTP Port 10077. Response received correctly with no translation. Phase 4-78 check passed.
    <14:09:10>: UDP RTP Port 10078. Response received correctly with no translation. Phase 4-79 check passed.
    <14:09:10>: UDP RTP Port 10079. Response received correctly with no translation. Phase 4-80 check passed.
    <14:09:10>: UDP RTP Port 10080. Response received correctly with no translation. Phase 4-81 check passed.
    <14:09:10>: UDP RTP Port 10081. Response received correctly with no translation. Phase 4-82 check passed.
    <14:09:10>: UDP RTP Port 10082. Response received correctly with no translation. Phase 4-83 check passed.
    <14:09:10>: UDP RTP Port 10083. Response received correctly with no translation. Phase 4-84 check passed.
    <14:09:10>: UDP RTP Port 10084. Response received correctly with no translation. Phase 4-85 check passed.
    <14:09:10>: UDP RTP Port 10085. Response received correctly with no translation. Phase 4-86 check passed.
    <14:09:10>: UDP RTP Port 10086. Response received correctly with no translation. Phase 4-87 check passed.
    <14:09:10>: UDP RTP Port 10087. Response received correctly with no translation. Phase 4-88 check passed.
    <14:09:10>: UDP RTP Port 10088. Response received correctly with no translation. Phase 4-89 check passed.
    <14:09:10>: UDP RTP Port 10089. Response received correctly with no translation. Phase 4-90 check passed.
    <14:09:10>: UDP RTP Port 10090. Response received correctly with no translation. Phase 4-91 check passed.
    <14:09:10>: UDP RTP Port 10091. Response received correctly with no translation. Phase 4-92 check passed.
    <14:09:10>: UDP RTP Port 10092. Response received correctly with no translation. Phase 4-93 check passed.
    <14:09:10>: UDP RTP Port 10093. Response received correctly with no translation. Phase 4-94 check passed.
    <14:09:10>: UDP RTP Port 10094. Response received correctly with no translation. Phase 4-95 check passed.
    <14:09:10>: UDP RTP Port 10095. Response received correctly with no translation. Phase 4-96 check passed.
    <14:09:10>: UDP RTP Port 10096. Response received correctly with no translation. Phase 4-97 check passed.
    <14:09:10>: UDP RTP Port 10097. Response received correctly with no translation. Phase 4-98 check passed.
    <14:09:10>: UDP RTP Port 10098. Response received correctly with no translation. Phase 4-99 check passed.
    <14:09:10>: UDP RTP Port 10099. Response received correctly with no translation. Phase 4-100 check passed.
    <14:09:10>: UDP RTP Port 10100. Response received correctly with no translation. Phase 4-101 check passed.
    Application exit code is 0
  5. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    What is the source of the "Im almost 100% sure is a 3CX problem"?
    How does STUN server "is able to resolve my DDNS"?
  6. smontano
    Jan 3, 2010
    5
    Sorry for the DDNS resolve. I mean, it does resolve my external IP.
    15:24:48.191 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 64.69.76.21:3478 over Transport 172.16.1.10:5060
    On my router, i forwarded this ports to my 3CX PBX
    5060 - 5090
    10000-20000
    On my PBX
    Internal ports: 10000 - 10010
    External ports: 10011 - 10100
    I just did another call:
    15:36:52.693 [MS105000] C:13.2: No RTP packets were received:remoteAddr=189.161.91.69:49212,extAddr=0.0.0.0:0,localAddr=172.16.1.10:10006
    As i understand, it taking this call as internal and not external
  7. SY
    3CX Support
    Jan 26, 2007
    1,825
    Sorry but... Could you please answer questions first.
    p.s. "As i understand, it taking this call as internal and not external". Yes you are right.
  8. smontano
    Jan 3, 2010
    5
    when i mentioned 100% sure its a 3CX problem, is because with asterisk it works fine using port forwarded, all calls to external ATA (internet) works fien.. no one way audio problem.
    For the STUN server, what i was trying to say, is my external ATA's can resolve my DDNS. sorry for that =(
  9. SY
    3CX Support
    Jan 26, 2007
    1,825
    Could you please provide more information which is not bound to "*"? (see "p.s." in my post)
    p.s. I hope you have read the http://www.3cx.com/forums/forum-rules-read-to-get-answers-93.html
