One-way Audio
Discussion in '3CX Phone System - General' started by mfretwell, Aug 15, 2008.
  1. mfretwell
    May 26, 2008
    25
    Internal caller cannot hear external caller.
  2. alexmallia
    alexmallia New Member
    3CX Support
    Aug 4, 2008
    130
    Is the incoming call coming via a VOIP provider or a PSTN line? Does this happen on an incoming, outgoing or both type of calls?
    If using a VOIP provider, does the VOIP connection pass trough a firewall?
    Do you have the Microsoft firewall running on the 3CX machine?
    In the lines configuration have you set the PBX delivers audio or no?
    What are you using as a Phone Client? Do you use the 3CX client?
  3. mfretwell
    May 26, 2008
    25
    In answer to your questions:
    VOIP = Vonage
    Firewall = SonicWall 2040
    Microsoft firewall = off, Trend Micro firewall = off
    PBX delivers audio = off
    Phone client = Aastra i55 SIP phone
  4. amygoda
    amygoda Member
    Sep 18, 2006
    436
    set stun server in aastra and/or PBX delivers audio = on
  5. mfretwell
    May 26, 2008
    25
    Just tried setting, PBX delivers audio = ON
    In 3CX for both the extension "other options" and gateway/provider "other options".
    Aastra appears to have no such switch in the firmware.
    Still only have outbound audio.
    Please also note that an X-Pro Softphone works with no problem on the same server as 3CX resides. X-Pro has not been running while testing 3CX but is installed to test connectivity and isolate firewall issues.
  6. worksighted
    worksighted New Member
    Aug 19, 2008
    204
    Does your 3CX box pass the builtin firewall test? Are you allowing UDP 9000-9015 from firewall to 3cx? I havent used vonage as a provider with 3cx but these are the standard voip provider ports.
    Can the 55i receive internal ext to ext calls with audio OK?
    You should need pbx delivers audio with the 55i as they support the standard codecs. I have several of them that work flawlessly.
    Mike
  7. mfretwell
    May 26, 2008
    25
    Firewall test is fine.
    9000-9015 are open.
    Have only one 55i for testing before buying complete set for office, so we can't test int ext to ext.
  8. worksighted
    Aug 19, 2008
    204
    If you launch wireshark on your laptop are you seeing the RTP traffic getting there?
    Mike
