One way voice on Android with 3G, but I get 2 way on Wifi
Discussion in 'Android' started by nokia9600, Dec 11, 2010.
  1. nokia9600
    Dec 11, 2010
    I have a really big problem: On 3Cx voip sw over Android 2.2 (galaxy s samsung)
    I have one way voice only tx (out to net) but I don't listen anythings in Rx.
    I get two way audio on WiFi but not 3cx phone on 3G registration.
    I have try all configuration avaible on 3cx, without any result.
    Please help Me
    regards to all forum
    Robert
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Re: One way voice on Android with 3G, but I get 2 way on Wif
    Check out service pack 5, there is a potential fix. This solved my problems with a Samsung Vibrant on T-Mobile.
  3. mmoreice
    Sep 22, 2007
    Port 5060 open on SIP-server?
    Ports 10000-20000 open to SIP-server?
    NAT enabled on both Sip client and PBX?
    Cheers,
    MmoreIce
