OnHold Sound
Discussion in '3CX Phone System - General' started by Dcodri, May 14, 2012.
  1. Dcodri
    May 14, 2012
    Good day,
    How do you lower the onhold music that plays while someone is on hold. It appears to be too loud.
  2. netswork
    netswork Active Member
    Mar 11, 2011
    577
    The only way I have to do what your talking about is to use audacity to lower the volume of the wav file, then upload the file back to the server.
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,586
    309
    same here... that was suggested to me from someone at 3cx.
  4. paul.hadley
    paul.hadley New Member
    Aug 24, 2010
    122
    Windows includes "Sound Recorder" which you can use to open "wav" files. This allows the file once open to have its volume lowered by 25% and then saved. If you need it even lower just do it again.
    In windows XP & Server 2003 it is located at %SystemRoot%\system32\sndrec32.exe
