ONLINE WITH Build version 5.1.4128
Discussion in '3CX Phone System - General' started by kirimis, Mar 5, 2008.
  1. kirimis
    Oct 16, 2007
    43
    Finally i crossed my fingers and decided to install Build version 5.1.4128 leaving the stable 3.1. Good news everything was ok. Patton with my 4 ISDN line was stable , no echos, no faults, all incoming and outgoing was ok, on hold music fine and better sound quality. But a problem came up with grandstream GXW4104 and my 4 analog lines. My GXW4104 has version 1.0.1.2 ,so i came up with lowest quality of sound , digital receprtionist voice strangled and cut, dropping of lines and generally the telephone as it was at 40s :lol: in the worst scenario. Build version 5.1.4128 is stable in general, only bag is that couple of times on of my 4 ISDN lines was stack yellow even if patton had no active calls(minor).
    SO once again i am looking for help with GXW4104 .Is there a way to correct things around this device? If this is accomblished i will have managed with your help to setup the perfect 3cx call center for me.
    Thanks in advance
