only able to receive one inbound call at a time
Discussion in '3CX Phone System - General' started by maso, May 29, 2008.
  1. maso
    May 29, 2008
    6
    I have a setup as follows:
    sip.internode.on.net --> 3cx on a server --> snom handsets
    My voip account has 4 channels and i can make 4 outbound calls concurrently. I can receive 1 call, but any subsequent inbound calls are received by my providers voice mail system. I have spoken to my voip provider and they claim the system is set up correctly at their end.
    I have the Voip line registered in 3cx as a generic line, stun is on and seems to be working.
    I would post from the logs but there is nothing to see after the first connection.
  2. ktikoft
    Jun 22, 2007
    59
    Hi this is probably the general settinsg ports to use for external calls Under General.
    Also check these ports are open on your firewall.
    I would suspect you will find there is some port blocking going on.
    BTW
    I am using The Engin Business Service with no problems for 10 months
    15 Grandstream Phones,
    Old HP server early model 2.8 xeon running DC, Exchange, Rightfax, DNS and backup software
    I looked at nodefone but the price was not compentitve. I looked at MyNetFone as well but they did not support G711 and i wanted the highest quality calls.
  3. maso
    May 29, 2008
    6
    I have the Sip Port under general settings on 5060 - should this be a single port or a range? The firewall test reports all is working.
  4. ktikoft
    Jun 22, 2007
    59
    Two things "ports to use" for external calls and also 5060 is only the starting port. The next call will come in on 5061 etc etc.
    Also open up your firewall a bit to allow all traffic from internode to the server, you can lock it down later
  5. maso
    May 29, 2008
    6
    ok, i have turned off the firewall and port forwarded all ports from sip.internode.on.net to the server. still no luck receiving more than one call at a time
  6. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Any logs?
  7. maso
    May 29, 2008
    6
    Hi archie,
    Hmm, its' out of office hours here and i was able to connect two incoming calls. Must be something to do with my ring group...sorry to waste both of your time and thanks for the help.
  8. maso
    May 29, 2008
    6
    Ugh! The message was changed on the voip providers message service I and mistook it for the 3cx voicemail. Did not get two lines in at all.
    archie, if you are still interested here are the logs:
    22:11:38.831 MediaServerReporting::SetRemoteParty [MS210003] C:4.2:Answer provided. Connection(transcoding mode):127.0.0.1:7008(7009)
    22:11:38.831 MediaServerReporting::SetRemoteParty [MS210000] C:4.2:Offer received. RTP connection: 127.0.0.1:42010(42011)
    22:11:38.831 CallLeg::setRemoteSdp Remote SDP is set for legC:4.2
    22:11:34.987 CallLeg::eek:nConfirmed Session 110 of leg C:4.1 is confirmed
    22:11:34.831 CallCtrl::eek:nLegConnected [CM503007]: Call(4): Device joined: sip:104@127.0.0.1:5070;rinstance=7864e06928271a63
    22:11:34.831 LineCfg::getInboundTarget [CM503011]: Inbound out-of-office hours' rule for LN:10000 forwards to DN:800
    22:11:34.815 CallCtrl::eek:nLegConnected [CM503007]: Call(4): Device joined: sip:0290432448@203.2.134.1:5060
    22:11:34.815 MediaServerReporting::SetRemoteParty [MS210003] C:4.1:Answer provided. Connection(transcoding mode):150.101.202.229:9006(9007)
    22:11:34.815 MediaServerReporting::SetRemoteParty [MS210001] C:4.2:Answer received. RTP connection: 127.0.0.1:42010(42011)
    22:11:34.799 CallLeg::setRemoteSdp Remote SDP is set for legC:4.2
    22:11:32.190 Extension::printEndpointInfo [CM505001]: Ext.104: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX VoIP Client;Rev: 1] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Phone v5.1] Transport: [sip:192.168.1.1:5060]
    22:11:32.190 CallCtrl::eek:nAnsweredCall [CM503002]: Call(4): Alerting sip:104@127.0.0.1:5070;rinstance=7864e06928271a63
    22:11:31.893 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(4): Calling: HuntGrp:800@[Dev:sip:103@192.168.1.108:2051;line=wkya7tfs]
    22:11:31.893 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(4): Calling: HuntGrp:800@[Dev:sip:102@192.168.1.103:2051;line=ofjz9ilm]
    22:11:31.893 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(4): Calling: HuntGrp:800@[Dev:sip:101@192.168.1.109:2051;line=ux83x3v1]
    22:11:31.893 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(4): Calling: HuntGrp:800@[Dev:sip:100@192.168.1.110:2051;line=zjgu9kmt]
    22:11:31.893 MediaServerReporting::SetRemoteParty [MS210002] C:4.2:Offer provided. Connection(transcoding mode): 127.0.0.1:7008(7009)
    22:11:31.877 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(4): Calling: HuntGrp:800@[Dev:sip:104@127.0.0.1:5070;rinstance=7864e06928271a63]
    22:11:31.877 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:800@FGI00.fgi.local:5060]
    22:11:31.877 MediaServerReporting::SetRemoteParty [MS210000] C:4.1:Offer received. RTP connection: 203.2.134.1:25650(25651)
    22:11:31.877 CallLeg::setRemoteSdp Remote SDP is set for legC:4.1
    22:11:31.877 Line::printEndpointInfo [CM505003]: Provider:[node] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] Transport: [sip:192.168.1.1:5060]
    22:11:31.877 LineCfg::getInboundTarget [CM503011]: Inbound out-of-office hours' rule for LN:10000 forwards to DN:800
    22:11:31.862 CallCtrl::eek:nIncomingCall [CM503001]: Call(4): Incoming call from anonymous@(Ln.10000@node) to [sip:800@FGI00.fgi.local:5060]
    22:11:31.581 LineCfg::getInboundTarget [CM503011]: Inbound out-of-office hours' rule for LN:10000 forwards to DN:800
    22:11:31.549 CallLeg::eek:nNewCall [CM500002]: Info on incoming INVITE:
    INVITE sip:0290432448@150.101.202.229:5060;rinstance=561fbb58dc7e2e5c SIP/2.0
    Via: SIP/2.0/UDP 203.2.134.1:5060;branch=z9hG4bK9ds2g300a0t1rdo3b241.1
    Max-Forwards: 9
    Contact: [sip:anonymous@203.2.134.1:5060;transport=udp]
    To: [sip:0290432448@sip.internode.on.net;user=phone]
    From: "Anonymous"[sip:anonymous@anonymous.invalid];tag=1172109904-1212063093920-
    Call-ID: BW214133920290508629475702@203.2.134.129
    CSeq: 441158225 INVITE
    Accept: multipart/mixed, application/sdp
    Allow: ACK, BYE, CANCEL, INFO, INVITE, OPTIONS, PRACK, REFER, UPDATE, NOTIFY
    Supported: 100rel
    Content-Length: 0
  9. archie
    3CX Support
    Aug 18, 2006
    1,299
    I see no problem, call has been established to 3CX VoIP client (supposedly) which is located on PBX server.
  10. maso
    May 29, 2008
    6
    Signed with engin this morning and no problems. Internode are looking into it.
  11. ktikoft
    Jun 22, 2007
    59
    Engin work out of the box one of the reasons we went with them the other is cost. For Autralia they are cheap but not the cheapest :)
