Only enable one outgoing number for extention
Discussion in '3CX Phone System - General' started by zccit, Mar 1, 2016.
  1. zccit
    Apr 22, 2013
    12
    3CX v14 SP3
    Situation: Elevator with analog phone. (Phone > beronet > 3CX)
    Wish: Setup extension xxx so it can only dial number yyy (internal numbers)
    In the extension options there is a option disable external numbers. That's also great.
    But i can't find "Can only dial to extension xxx" :)
    Is there a other option to get this done?
    Regards,
    Jan
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,947
    179
    Does the beronet have a Off-hook Auto Dial feature?
    3cx does not have what you are looking for. Most Voip devices seem to.
  3. zccit
    Apr 22, 2013
    12
    Good suggestion :) ..beronet have a Off-hook Auto Dial feature
    I will contact them.
    Regards,
    Jan
