only external ip
Discussion in '3CX Phone System - General' started by bluetel2, Feb 10, 2012.
  1. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
    Hi all,
    we have dedicated serveur which have only 1 network card. this network card is link directly to net. ip addresse ip external add. so the ip add of pbx is a loopback network card.
    my problem is with tunnel. when i said to my tunnel to listen on local ip -> finaly external ip, my 3cx phone connect but there is no audio.
    when i said to tunnel on 3cx phonse system to liste local ip 192.168.2.1 (my loppback ip) 3cx phone can connect.
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    814
    49
    I ran into the same problem with one of my customers. It was solved as follows
    In 3CX server
    Go to Settings >> Network >> 3CX Tunnel >> Local IP - select your external (WAN) IP-address
    Go to Settings >> Advanced >> Advanced >> Local SIP domain - fill in your WAN IP-address
    In 3CXPhone
    Go to Account Settings >> My Location >> I am out of the office - fill in the WAN IP-address of the 3CX server
    Select Use 3CX Tunnel >> Local IP - fill in the WAN IP-address of the 3CX server.
  3. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
    Tks frank for your reply,
    in fact i test this but i have only 1 way audio. on 3cx phone connected is write 127.0.0.1:54585 ?? i don't know why this port and why this ip?
    tks
  4. complex1
    Jan 25, 2010
    814
    49
    I presume that you also, in 3CX server, set STUN as follows
    Tick the Turn off stun server
    Public IP is your WAN IP-address
    Select Network card Interface to your WAN IP-address
    The port number, when the 3CXPhone connects to the server by tunnel or direct, is never port 5060. It is always random. Why? I don’t know. But it works.
    Also the IP-address 127.0.0.1 is normal if 3CXPhone is connect via a tunnel.
  5. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
    it's 2008 policies problem
    tks
