Open a Socket
Discussion in 'Call Flow Designer' started by imagemaster, Nov 25, 2017.
  1. imagemaster
    Jul 20, 2010
    46
    What is the timeout period in waiting for a response?
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,609
    126
    Hello @imagemaster,
    Currently the timeout is the default value for the NetworkStream, which is Infinite (wait forever).
    We will add a new property to the component to allow setting a different value.
    Kind regards.
  3. imagemaster
    Jul 20, 2010
    46
    There is no need for an additional parameter. I was confirming that it was indefinite. From a programming point of view, if you check the box to wait for a response it is because one must be sent. Otherwise other code will break.
