open ports on Router Dlink Di-604
Discussion in '3CX Phone System - General' started by jose_chile, Sep 14, 2007.
  1. jose_chile
    Sep 3, 2007
    8
    Hi, i install 3cx free on my office, conecting directly the modem with Lan Card of my server, and all work Fine. But i Buy a router Dlink di-604 and now not work. Viewing some forums, and your manual, say that i must open port 5060, 3478 , 5481, 7000-7250, 9000-9250. But if i do that the remote ata dont conect and i can`t see the stun server. If i enable the virtual server of Di-604 and add ports 5060, the remote ata conect but dont make calls.
    Do you have some manual for configure Router Dlink DI-604 ???
    Jose
  2. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    D-Link manual at http://www.dlink.ca/product.php?PID=145. If you are asking does 3CX have specific setup info for this Router the answer in no, too many models and methods in the world. I have this model router and have STUN under "Virtual Server" with all other ports under "Firewall". Port range 7000-7250 is for internal use only, not needed on router to the best of my knowledge. Port 5481 only if you wish external access to 3CX admin, as you know.
  3. touficjohn
    Sep 5, 2007
    20
    Here have a look at this post should shed some light on what ports to open and maybe portforward.com has your router listed :)
    http://www.3cx.com/forums/categories-1/3cx-phone-system-general-1/the-portforwarding-faq-hope-this-gets-a-sticky-1697/?highlight=portforward
  4. ecwilson
    ecwilson New Member
    Jul 12, 2007
    118
    Take a look at this post it worked for us & no port configurations at all.
    We are using a linksys router & grandstream phones. I hope this helps
    http://www.3cx.com/forums/categories-1/3cx-phone-system-general-1/data-ceter-setup-remote-extension-will-not-ring-2321/
    ecwilson
