Open Ports
Discussion in '3CX Phone System - General' started by bara, Sep 23, 2008.
  1. bara
    Sep 23, 2008
    6
    Which port need to be opend and redirect on the router to the PC holding the 3CX?
  2. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello
    5060:5066 udp,tcp
    5481 tcp
    5090 for tunnel
  3. bara
    Sep 23, 2008
    6
    Thanks for your help
  4. worksighted
    worksighted New Member
    Aug 19, 2008
    204
    Are you using a VOIP prvider? If so, you need those ports as well. UDP 9000-9015 for Small Business.
  5. bara
    Sep 23, 2008
    6
    I am trying to use BT Broadband talk 056.. number, don't know yet how to configure it, do you have any information?
  6. Discovery Technology
    Apr 19, 2008
    278
    You might want to be careful opening up 5481 to the web as this is the listening port for the GUI (unless you really need to access this from the outside) - at least make sure you have a good password, otherwise 5481 isn't crucial to the running of calls, it is the remote access port to access the GUI only.
