operator error
Discussion in '3CX Phone System - General' started by abelaguilar, Nov 20, 2007.
  1. abelaguilar
    Nov 4, 2007
    94
    When I try to dial 9 1888xxx-xxxx I get the operator error stating "you must first dial a 1 or a 0 plus the area code" I get this even though I am dialing the proper digits.
    Sometimes I goes through. There is a timing problem I think. Anyway that I can fix this?
  2. abelaguilar
    Nov 4, 2007
    94
    I wonder if my polycom 501 settings need to be tweaked.
  3. abelaguilar
    Nov 4, 2007
    94
    Anybody have a suggestion for this?
  4. abelaguilar
    Nov 4, 2007
    94
    wondering if someone can help with this please.
  5. webguyz
    webguyz New Member
    Jul 19, 2007
    126
    In the outbound gateway edit you need to make sure there is a single lower case 'r' in the field labeled: Transform mask (optional)
    This tells the pbx to remove 1st number before dialing
    so if your using 91xxx-xxx-xxxx, the r tells it too remove the 9 before dialing out.
  6. abelaguilar
    Nov 4, 2007
    94
    Does version 5 have this field?
  7. webguyz
    webguyz New Member
    Jul 19, 2007
    126
    Didn't realize you were using 5 but it would have to have something similar, otherwise how would it know what parts of what your dialing are signal for getting an outside line and which are the actual phone number.
  8. Mori
    Mori New Member
    Mar 23, 2007
    223
    Yes, but it has changed abit from v.3.
    Go to "Manage Outbound rules", pick your Provider/Gateway to edit.
    Under "Apply this rule to these calls" you have a line "Calls to Numbers starting with (Prefix)".
    This is your number to get external line. (In your case a 9?)
    Further down, under "Make Outbound Calls on" you have a line "Route 1". Here you decide how many numbers to strip from dialplan. (In your case 1 number).
    This will make 3cx strip the "9" from outbound call and your number dialing will be 1888xxx-xxxx.
