Operator EXT 1000 returns Busy status
Discussion in '3CX Phone System - General' started by swim, Jul 12, 2011.
  1. swim
    Sep 23, 2008
    26
    Any help on this would be much apreciated as I can not work this out :S
    3CX V 10 sp 1.1
    server 2008
    Hyper V install
    3 Snom 820 ip phones
    All extensions work correctly internally and externally except extension 1000
    test call from extension 1001 to 1000
    19:01:29.267 Currently active calls [none]
    19:01:21.940 [CM503008]: Call(1): Call is terminated
    19:01:19.009 Session 350 of leg C:1.1 is confirmed
    19:01:18.368 [CM503007]: Call(1): Device joined: sip:5555@127.0.0.1:40600;rinstance=ab31c3ef1274c968
    19:01:18.364 [CM503007]: Call(1): Device joined: sip:1001@192.168.1.38:1024;line=cduli2sd
    19:01:18.361 [MS210005] C:1.1:Answer provided. Connection(proxy mode):192.168.1.4:7000(7001)
    19:01:18.355 [MS210001] C:1.2:Answer received. RTP connection[unsecure]: 127.0.0.1:40610(40611)
    19:01:18.353 Remote SDP is set for legC:1.2
    19:01:18.346 [CM505001]: Ext.5555: Device info: Device Identified: [Man: 3CX Ltd.;Mod: Voice Mail Menu;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Voice Mail Menu] PBX contact: [sip:5555@127.0.0.1:5060]
    19:01:18.346 [CM503002]: Call(1): Alerting sip:5555@127.0.0.1:40600;rinstance=ab31c3ef1274c968
    19:01:18.203 [CM503025]: Call(1): Calling Ext:Ext.5555@[Dev:sip:5555@127.0.0.1:40600;rinstance=ab31c3ef1274c968]
    19:01:18.200 [MS210004] C:1.2:Offer provided. Connection(proxy mode): 127.0.0.1:7002(7003)
    19:01:18.144 [CM503005]: Call(1): Forwarding: Ext:Ext.5555@[Dev:sip:5555@127.0.0.1:40600;rinstance=ab31c3ef1274c968]
    19:01:18.138 [CM503016]: Call(1): Attempt to reach <sip:1000@192.168.1.4:5060;user=phone> failed. Reason: Busy
    19:01:18.138 [CM503014]: Call(1): No known route to target: <sip:1000@192.168.1.4:5060;user=phone>
    19:01:18.115 [CM503010]: Making route(s) to <sip:1000@192.168.1.4:5060;user=phone>
    19:01:18.113 [MS210000] C:1.1:Offer received. RTP connection: 192.168.1.38:50656(50657)
    19:01:18.110 Remote SDP is set for legC:1.1
    19:01:18.110 [CM505001]: Ext.1001: Device info: Device Identified: [Man: Snom;Mod: 8xx series;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom820/8.4.31] PBX contact: [sip:1001@192.168.1.4:5060]
    19:01:18.106 [CM503001]: Call(1): Incoming call from Ext.1001 to <sip:1000@192.168.1.4:5060;user=phone>
    19:01:17.024 [CM500002]: Info on incoming INVITE:
    INVITE sip:1000@192.168.1.4:5060;user=phone SIP/2.0
    Via: SIP/2.0/UDP 192.168.1.38:1024;branch=z9hG4bK-p4iml6nnioys;rport=1024
    Max-Forwards: 70
    Contact: <sip:1001@192.168.1.38:1024;line=cduli2sd>;reg-id=1
    To: <sip:1000@192.168.1.4:5060;user=phone>
    From: "Tracie "<sip:1001@192.168.1.4:5060>;tag=0smw8pe42f
    Call-ID: 3c2ea10f6b60-9g8nv46dx312
    CSeq: 2 INVITE
    Session-Expires: 3600;refresher=uas
    Min-SE: 90
    Accept: application/sdp
    Allow: INVITE, ACK, CANCEL, BYE, REFER, OPTIONS, NOTIFY, SUBSCRIBE, PRACK, MESSAGE, INFO, UPDATE
    Proxy-Authorization: Digest username="1001",realm="3CXPhoneSystem",nonce="414d535c042d1cec22:52256b4c1b70cb8220a26aef7ceed2d4",uri="sip:1000@192.168.1.4:5060;user=phone",response="8a9bb4124d28e113808b8af21253c994",algorithm=MD5
    Supported: timer, 100rel, replaces, from-change
    User-Agent: snom820/8.4.31
    Allow-Events: talk, hold, refer, call-info
    Content-Length: 0
    X-Serialnumber:removed
    P-Key-Flags: resolution="31x13", keys="4"
    19:00:57.267 Currently active calls [none]
    19:00:51.329 [CM504001]: Ext.1000: new contact is registered. Contact(s): [sip:1000@192.168.1.37:1024;line=e7w8wg8t/1000]
    many thanks :)
    10,587
    253
    It looks like 3CX can't find Ext 1000 (not registered?), but 1000 is forwarded to Ext 5555, and that is where the call is going.
  3. swim
    Sep 23, 2008
    26
    thanks for the reply leejor, its really bizzare as 3cx management console shows extension 1000 as registered, the snom phone shows extension 1000 as registered and the 3CX logs show extension 1000 as registered.
    I have tested extension 1000 by moving it to different phones and every time I get failed. Reason: Busy from the logs and you are correct the call goes to voicemail 5555
    therefore I can rule out the hard phones, and point the issue to the extension itself ( which shows as available and logged in )
    just cant get my head round this one :S
  4. nbailey
    nbailey Member
    Jan 31, 2011
    359
    sounds like DND is set possibly and the extension is set to forward to ext 5555, as it doesn't show DND status in the phone system trying giving that a glance, I don't work with snom phones so I can't help you with the settings.
    Thanks,
    Nate
  5. swim
    Sep 23, 2008
    26
    thanks Nate, it does sound like DND is "stuck" on, I can toggle DND on/off with the snom phone with no effect, also to confirm that I have put this extension on 3 different Snom phones which replicates the same problem. I can also replicate the same issue with a 3cx softphone.
  6. StefanW
    Jun 2, 2009
    1,210
    85
    go to the phone and dial once *60, does this solve the issue?
