Operator Extension - Receive mutiple calls
Discussion in '3CX Phone System - General' started by quayfour, Sep 8, 2011.
  1. quayfour
    Dec 1, 2009
    12
    I am using a Yealink T28 and have an opertor extension 100
    I would like to be able to handle multiple incoming calls on the phone.
    Receive call 1 place on hold
    receive call 2 place on Hold
    Toggle between calls.
    At the moment a second call just overflows to the overflow ring group.
    Any suggestions.
  2. willow
    willow Member
    Mar 1, 2011
    471
    #2 willow, Sep 8, 2011
  3. leejor
    11,113
    329
    Have you tried assigning the extension (100), to multiple keys on the set, then setting the extension option in 3CX to allow more than one call at a time.
