Operator Extension - V7 Potential Bug
Discussion in '3CX Phone System - General' started by SnAzBaZ, Dec 18, 2008.
  1. SnAzBaZ
    Nov 9, 2007
    28
    I have set the Operator Extension to something other than the default 100, however in my call log call's are still being transferred to 100. Also, it appears to be the SIP ID field and not the actual extension number you need to set in that field.
    This happens when people press * to connect to the operator via the voicemail menu.
    Anyone else notice this, or have I configured something incorrectly ?
    Andrew
  2. alexmallia
    alexmallia New Member
    3CX Support
    Aug 4, 2008
    130
    We are currently working on this issue.
    It is recommended you open a support case with support on this so it can be handled via the support system.
    regards
  3. SnAzBaZ
    Nov 9, 2007
    28
    I don't have a support contract for 3CX yet, as we have not needed any support. So not sure how I can do that without one!
    Andrew
  4. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,994
    306
    We are looking into it. If it is a general issue it will be posted to the forum in the v7 thread.
